code numbers
Old 06-03-2005, 11:20 AM
Z-286speed's Avatar
Default code numbers
p0135, p0155, p0803, and p0102. If anyone one help me out with these codes, its making my car run really really bad. I know two of them are 02 and one is a MAF.
Old 06-03-2005, 11:28 AM
horist's Avatar
did you just recently install the long tube headers?
Check the "Engine Sensor" fuse under the hood, it's probably blown
Old 06-03-2005, 11:34 AM
horist's Avatar
P0135 HO2S Heater Circuit Bank 1 Sensor 1
P0155 Heated Oxygen Sensor Heater Circuit (bank 2, sensor 1)
P0102 Mass Air Flow Sensor Circuit Low Frequency
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit
Not sure if the skipshift is on the same circuit... but the O2s and MAF are on the same circuit.. so if engine sensor blows, it'll set all those codes
It also puts you into Open Loop Speed Density... which a car not tuned for it will run like complete ***
Now the trick is... why did the fuse blow (If that's it) ... check the O2 wires... I bet one is hitting the header and the wire melted through
Old 06-03-2005, 02:04 PM
Z-286speed's Avatar
I did just recently splice those wires, so there could be a problem there. I am going to check the engine sensor right now and all of those fuses. I might just have a bad connection on those sensors, or hope to god i do.
Old 06-03-2005, 02:11 PM
Z-286speed's Avatar
O, and i just had a cam put in, i ran with out 02s in the front for a little while, then had them put in, but tuned for it. I will be back here in 15 mins after i check every thing.
Old 06-03-2005, 03:26 PM
Z-286speed's Avatar
Runs perfect now, replaced the fuse, Thanks a lot guys!
Old 06-17-2005, 02:10 AM
aNuBiS's Avatar
where bouts was the fuse? was it one of the ones under the hood?
Old 06-17-2005, 02:15 PM
superduty's Avatar
Thanks for this thread. You solved our issue too! We crushed the O2 wire on the ground and shorted out the fuse. Threw these codes and now that the fuse is replaced, it's back to normal!
Old 08-21-2005, 12:25 PM
Ryan G's Avatar
I'm having some problems with my car. Running really crappy, idle issues, really boggy when giving gas...ect...ect.
I took the car to autozone yesterday and it threw 4 codes...
P0121 - TPS/Pedal Position
P0154 - O2 Sensor
P0300 - Random/Mutiple Cylinder Misfire
P0412 - Secondary Air Injection System
I have no idea what would cause these codes. I tried replacing the TPS in the parking lot and it didn't fix the problem. Hopefully it may be just a blown Engine Sensor Fuse?
Does anyone know the part number for the engine sensor so I can maybe try that?
Thanks,
Ryan
Old 08-21-2005, 12:39 PM
horist's Avatar
just go under the hood and pull the fuse (it's marked on one of the underhood fuse boxes) . you can tell by looking at it if it's blown or not.. if it is blown Radio Shack carries what you need (just go in w/the fuse)
Your situation doesn't sound like a blown engine sensor fuse though... when this started hapening was it after any mods? Probably want to start a new thread to get more ideas/responses
