A4 to MN6...How To Wire Clutch Neutral Safety Switch
Old 06-03-2005, 05:37 PM
usmuscl's Avatar
Default A4 to MN6...How To Wire Clutch Neutral Safety Switch
Hey,
Almost done my A4 to MN6 Swap in my 2000 Vette. Put in the clutch pedal assembly. There are 2 sensors on it...One towards the firewall for the clutch neutral safety switch so the car only turns on when the clutch is fully engaged. And I presume the other is for cruise control which I dont care about.
How am I supposed to wire the clutch neutral safety switch? From what to what? Any other wiring I will need to do?
Also for the CAGs...do I need to do anything special for that? Does that need to have a wire run to it as well? Or just install the CAGs defeat and i'm done.
Thanks!!!
