What is the deal?
Old 06-04-2005, 03:05 AM
Nocturnal SS's Avatar
Question What is the deal?
I got a 2002 Camaro SS with a 3200 stall speed converter. Anyway I was told that when I do my burnouts I should put the car in first then do the burnout, I have allways done the burnout in 3rd,but someone said this is no good for the car. So I did the burnout in 1st then took it up to the light,put it in 3rd ,and took off. Now ever time I do this my car hits the rev limiter in 2nd 2 weeks in a row at the track it has done this forcing me to do the burnout in 3rd, I got the car program on LS1 edit. It is set to shift at 6350,and the rev limiter is set at 6700 RPM. What is the deal here? Doe's anybody have an answer to what is going on here? I sure could use someones advice.
Old 06-06-2005, 02:26 AM
Can someone answer this question? Can"t br that tough.
Old 06-06-2005, 03:30 AM
((((((Administrator))))))
CRAGER's Avatar
I moved this to the Automatic Transmission Section so you can get better help.
You should try doing a search as well.
Peace,
Craig.
Old 06-07-2005, 09:00 AM
camaronut502's Avatar
i had the same problem friday night, first run ever in this car i forgot to put it into first so i did my burnout in D and the car went a 12.5 shifting fine, next run i put it in 1st do the burnout and it hit the rev. in 2nd had to get out of it and back on it for it to shift. some info would be great, and i tried searching but didnt really find much that i thought hit the subject on the head.
--Matt
Old 06-07-2005, 10:23 AM
King James's Avatar
Seems obvious to some, but did you check the tranny fluid level?
Old 06-10-2005, 03:49 AM
Someone said my trasmission is starting to go.
Old 06-11-2005, 02:20 AM
Yes I did.
Old 06-11-2005, 09:59 AM
toxic99's Avatar
I do not have an answer, but I have experienced something similiar. I always do my burnout in 1st then manually go to 2nd during the burnout. Then I put it in D to race. I've never hit the rev limiter with a healthy tranny. A friend of mine told me I should NOT be racing in D that I should be in 3rd. So, I gave it a shot but did my burnout the same way. I hit the rev limiter on both shifts. Keep in mine, my car shifts at 6500 and my rev limiter is set to 7200. So, it was really zinging. Needless to say, I do not race in 3rd anymore. Good luck though figuring it out.
Old 06-11-2005, 05:18 PM
black 2001Vette,Nightmare's Avatar
Well, if it's hitting the RL on all WOT 2-3 shifts, and you're having to back off to get into third, I would say you've fried your 3/4 clutches...if it is doing it whether racing in 3rd or OD.
Old 06-15-2005, 03:23 AM
But why would it do this only when I do the burn out in 1st, and not when I do the burn out in 3rd?Doe"s not make sense to me.
Old 06-15-2005, 08:27 AM
Ragtop 99's Avatar
Do your burn outs in first. That way you do not have a high rpm shift at part throttle line pressures.
FWIW, my car was much more consistent in shifting if I raced in OD (4th). When racing in D, my 2-3 shift would sometimes bounce off the limiter. This happens to other people; primarily when gear changes are on the mods list.
Old 06-16-2005, 02:17 AM
Default Iwas told!
I was told ,and I seen it myself that when you leave it in od (4th) you go about a tenth slower. I don"t know why this is ,but I seen it myself.
Old 06-17-2005, 03:02 AM
Question Overdrive?
So when I race the car at the track I leave it in (OD) never did that before.
Old 06-18-2005, 03:41 AM
I have the stock 3.23 in my car.
Old 06-23-2005, 02:59 AM
Is this a transmission problem,or a computer problem?
Called the boys a TSP, and they didn"t even know.
Old 06-24-2005, 03:31 AM
take into account this is the 1 2 shift, not the 2 3 shift.
