PAC Sensor Location?
Old 06-04-2005, 07:37 PM
InfiniteReality's Avatar
Default PAC Sensor Location?
I'm sure this question has been asked 100s of times, but I can't for the life of me find a good answer! Got a new screen, got a PAC and it's all wired. Just gotta find the best place for the sensor. What's the best place to mount it?
Old 06-04-2005, 09:04 PM
Richiec77's Avatar
Which sensor? For an alarm?
PAC makes lots of stuff.
What are you trying to wire up? Can't tell by what you posted.
<<EDIT>>OK. I just found another post about this camera here. Is this what you are talking about?
http://cgi.ebay.com/ws/eBayISAPI.dll...em=5774024818&
What PAC sensor is it?
Old 06-05-2005, 01:39 PM
Sorry for the confusion. I have the PAC adapter so I can use my steering wheel controls with my aftermarket headunit. I'm trying to find the best place to put the "eye".
Old 06-05-2005, 01:45 PM
Daley's Avatar
I've seen 'em put in the headliner between the T-tops (if applicable) as well as just in front of the shifter. It all depends on how creative and talented you are or want to be. Obviously, you don't want a location that would ever be blocked by anything.
Old 06-06-2005, 07:58 AM
T-tops is not a bad idea!
On a side note, wonder if it'd help if I upped the IR sensor to a 5mm. I have some really nice LED holders that would look good if so and maybe even the sensor would have a wider angle so it'd work better...
Old 06-07-2005, 09:16 PM
2002OrangeConv's Avatar
Doing this on Saturday. Does anyone have pics of there mounting locations. Especially on a convertable.
Thanks,
Rob
Old 06-10-2005, 07:12 PM
9silverbird8's Avatar
Thanks,
Rob
I'd be interested in this as well
Old 06-11-2005, 03:09 AM
98MidNtBlueBird's Avatar
ahh ill get some pictures on mine....
i mounted mine on the rubber part of the E-break..... i think its perfect for thoes who dont want to extend the IR cable...
Old 06-11-2005, 03:24 AM
SS 4 ME's Avatar
My husband drilled a 3/16" hole in the lower right hand side of the center panel, and it picks up the signal just fine. Here's a close-up view (sorry so fuzzy). The LED sensor is the little dot directly to the lower right of the head unit.
Another shot further away. The sensor is virtually unnoticable.
Old 06-11-2005, 05:29 AM
clemsondave's Avatar
I have also seen it mounted in the cupholder. Can't find the pic though.
