Guys that know Kenwood decks, help me out here
Guys that know Kenwood decks....help me out here...
I just bought a 2005 model Kenwood deck, the X789, and for the life of me I can't get it out of "demo mode." The book says to put it in standby, select "AM" or "FM" with the control **** (the one on the right that rotates 360 degrees and pushed in), and then press the control **** in for two seconds and that turns off the demo mode. When I'm in standby there is no AM or FM and pushing in the control **** or rotating it doesn't do a thing! What am I doing wrong here? Is the book a misprint? Anyone have any ideas? Thanks in advance....
Kenwood is apparently having numerous problems with this.
The "fix" is to hold down the 5 button and hold down reset but this only works on some players.
My fix would be to return it and buy a pioneer...
Ok, I checked, it was the button labeled "Q / Menu" - Hold it in for a few seconds and then press the control *** as many times as it takes to get to "DEMO ON" then press the *** in the direction of FM (UP) the display should now read "DEMO OFF" - Now you can rock out in peace - no more info about your deck on the display.
once you choose demo off you have to hold the play button down for a couple of seconds again for it to save it that way, I even unhooked mine for a minute and the demo mode was still off once I completed this
