Different AFR readings
Old 06-05-2005, 06:03 AM
Sport Side's Avatar
Default Different AFR readings
I'm trying to tune in SD but, I notice that my lm-1 is giving different readings than what my histogram is.
I'm seeing 12.5 across the entire board on the histogram but the lm-1 seems more accurate with readings around 14.7
I think something is wrong with the histogram but, does anyone have an idea?
Thanks.
Old 06-05-2005, 06:58 AM
Sport Side's Avatar
Now, I can not pull up the LM-1 manager. It says it is searching for the device. Analog out is plugged into the black box and then, ran to the lap top serial port.
If the LM-1 is reading correctly while tuning but, it is not showing up correctly in the histogram, I'm starting to think that my EIO isn't working.
Old 06-05-2005, 10:37 AM
bmfcamaro's Avatar
thats kinda what im going through.
Old 06-05-2005, 11:15 AM
txhorns281's Avatar
Have you check your table display to make sure you are logging LM-1 Wideband in the correct input cell? It's a simple thing to miss, and the first thing I would check.
Old 06-05-2005, 11:58 AM
Sport Side's Avatar
In the correct input cell? I'm not exactly sure what that means but I have added the LM-1 to the table display.
I'd like to think I've made a simple mistake but, I've used my wideband before and I think I have doubled checked all of my steps. Also, I find it odd that I can not open up the LM-1 manager which uses the EIO box to do so.
I'm pointing fingers at the EIO but, I'm really unsure at this point.
Thanks for your help Texas Horns.
Old 06-05-2005, 08:07 PM
MNC5's Avatar
Both your black box and Wide band have to share the same ground to the vehicle. If they don't the readings could be off. You'll find more info on the EFI website. Ground it to pin #4.. Is that how you did it?
Old 06-05-2005, 10:07 PM
txhorns281's Avatar
The bottom 3 rows are designated for the EIO. Some peeps don't know that! Just a thought... You said you can't connect the LM-1 to your laptop either though right? Are you going through a native serial port or USB adapter? Also, I'm sure you have, but check your wire splices too...
Again, just some thoughts... Hoping it's not yer EIO...
Old 06-06-2005, 06:35 AM
Sport Side's Avatar
Gotcha. Correct, it is not getting a reading. The unit is connected thru a USB adapter. Wouldn't work on my desktop either. But like I said, the LM-1 unit is giving correct readings while tuning. Just, it's not showing up correctly on the histogram display.
Thanks for helping me narrow it down. I think I'll be able to figure it out.
Old 06-06-2005, 02:14 PM
MNC5's Avatar
The other thing to remember is that AUX 1 on the LM-1 is setup incorrectly for what your doing. You'll need to program the voltage output on the LM-1 AUX 1 for the proper voltage. If you don't do that you'll get whacky readings that will only be close when its in range.
Old 06-06-2005, 03:16 PM
LS1TECH Sponsor
foff667's Avatar
i would assume he hasnt programmed the lm-1...thats what i did at first...read 12.5ish in all cells till i corrected it.
Old 06-06-2005, 07:49 PM
Sport Side's Avatar
Hmmm. Yeah, I corrected it the first time I ran the wideband. But, I had taken it out since then and now I was going to do some more tuning and I was getting the 12.5 readings.
I went to set it up, using the LM-1 manager but I couldn't get the lap top or my desktop computer to recognize it was connected. This is where I ran the lm-1 analog out thru the EIO into the lap by USB. It's possible the analog out cable is acting funny. I might try and rig up a 3.5mm stereo wire like I've seen mentioned here before.
Thanks for your help guys.
