P0342 + no run....
Old 06-05-2005, 12:20 PM
2001CamaroGuy's Avatar
Default P0342 + no run....
yesterday the car up and decided it no longer wants to run (ie: 11AM it cranked and ran........5PM it cranked but never "fired"....)......didn't touch anything.....
I started checking around and noticed a P0342 code (camshaft position sensor circuit low input)......so I cranked on it some more and noticed that ever once and a while I would get a pop like the spark plug had fired but out of phase........
so to me, this (the no run/spark plug fires at wrong time) points to either the crankshaft or camshaft sensor being bad.........
since I am getting a tach signal (both my autometer tach and the scanner show ~100-150 RPMs moving) as I crank, that the fire cycle seems out of phase, and then add the fact that I actually have a code for the camshaft sensor...........
sounds like a camshaft sensor right?
I checked the voltage on the sensor harness (12.2volts across the plug....computer is grounding/working/not burnt) and checked all fuses......any other things I might want to look at before I go to the parts deparment?
anyone else have a sensor like this just up and die?
Old 07-01-2005, 01:05 AM
speedo's Avatar
Me, The same thing is happening to my car.
Did you find the cause????
Old 07-02-2005, 01:42 PM
jmilz28's Avatar
Cam sensor is the most likely. COULD also be in the wiring or possibly the PCM. Take it to a respected dealer, pay for a diagnosis, then decide if you want them to fix it or tackle it yourself. Don't waste time throwing parts at it. Anytime you do a cam/crank sensor, I think you need to do a crank relearn procedure.
Quick Reply: P0342 + no run....
