Question about LT1 Gauge Cluster??
Does anyone know if you can switch a 94 Formula gauge cluster with an early 97 Cluster (the one with the manual odometer) Anyone know if you can do this? The couster is the same, except for that the 4 gauges on the bottom have the indicator picture inside the gauges, the 94 has them outside.
1 Post
The 97 cluster is digital, I have one to go into my 93 when the build is complete. No motor though so I can't tell ya if it works, I will try to get a buddy to bring his LT1 Fbody over, so I can swap and take a drive to see...
