Sponsored by: DashLynx
Blue T/A Steering Wheel Lights
Old 06-07-2005, 07:51 AM
InfiniteReality's Avatar
Default Blue T/A Steering Wheel Lights
I knew I was going to have to tackle this at some point, so last night I choose to do so. Now everything in my car, including my new screen lights up blue. Remember my car is a Trans Am and all use to be red! The steering wheel controls add a very nice finishing touch to it.
What I had to do:
1. Remove air bag fuse and air bag
2. With a flathead, removed steering wheel buttons and unplug
3. Find hot wire, which was the blue on each side
4. Desolder stock bulbs
5. Grinded the 3mm blue 7K LEDs heads flat and install
6. Under dash, I soldered one 100ohm resistor on the gray wire on the 4-wire plug coming out the steering column.
7. Test and reinstall everything.
Old 06-07-2005, 08:13 AM
shlim101's Avatar
looks freakin sweet...ive been too lazy to do mine. guess ill have to now
Old 06-07-2005, 08:39 AM
Yes you will! Finish it by this weekend, afterwards you'll be glad you did!!
Quick Reply: Blue T/A Steering Wheel Lights
