Vats
Vats
i have a 98 z28 auto
and the VATS system keeps going off
when i put in my key the security light will turn on and the car wont turn on after a while it turns off then the car turns on is there anyway i can overide the vats without ls1edit
I believe you need an editor to disable VATS... no way around that I *think* ... though you may want to ask some of the guys in the conversion section
Also , make sure the resistor in the key is clean... if it's not that could be what's cayusing it
