tnt problem
tnt problem
i bought the f2 kit for my lt1. since my heads are decked my intake is as well to match. it seems that when i go to install the tb plate it pushes the bottom of the tb into the thermostat housing. any sugestions...?
i dont have the money to set up a direct port, nor do i want to use a nos plate.
for what? i have intake manifold gaskets and im using gaskets between the plate, i guess thats the only 2 sets you could be asking about
Correct, if you are having clearance problems use RTV instead of gaskets and you should be fine..
