Overlap Formula
Originally Posted by Beast96Z
Either formula above nets the same end result.
Let us say 224/224 114lsa @ .050
so first formula (224+224/4)- (2x114)= -116
Second formula (224+224/2)- (2x114)= -4
How are these results the same??
14 Second Truck Club
So, do I want overlap to be closer to zero or further away? With my current cam I'm getting -14*, which performs great and sounds very badass. Then one of the ones I'm looking at for my LS1 (218/222-113) is -6* and the other one I'm looking at (220/224-113) is -4*. The -6* would give more lope of these two, right?
6600 rpm clutch dump of death Administrator
(-) less lope
(+) more lope
The less overlap the less lope.
(-) less lope
(+) more lope
(-) less lope
(+) more lope
Quick and Dirty Cam Calculator Spreadsheet
0.050
Intake Duration - ID 220
Exhaust Duration - ED 224
Lobe Center Angle - LCA (also known as LSA) 113
Intake Centerline - ICL 113
Intake Valve opens - IVO -3
Intake Valve closes - IVC 43
Exhaust Valve Opens - EVO 45
Exhaust Valve Closes - EVC -1
Exhaust Centerline - ECL 113
Overlap -4
0.050
Intake Duration - ID 218
Exhaust Duration - ED 222
Intake Valve opens - IVO -4
Intake Valve closes - IVC 42
Exhaust Valve Opens - EVO 44
Exhaust Valve Closes - EVC -2
Overlap -6
Neither should have much lope... The second one will have less though if any...
0.050
Overlap -4
0.050
Overlap -6
LS1 Tech Administrator
Some people think that LSA determines overlap.
Overlap is amount of time the exhaust lobe and intake lobe overlap each other. LSA is only a small component of this. Duration counts much more.
For example
210/216 106LSA cam = 1 degree of overlap at .050"
220/226 110LSA cam = 3 degrees of overlap at .050"
230/236 114LSA cam = 5 degrees of overlap at .050"
So even though my LSA got 4 degrees wider in each successive cam, the overlap grew as well. LSA and overlap do not necessarily go hand in hand.
For example
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
