biggest stall i can run and still spray?!
Old 06-08-2005, 05:38 PM
LS1_PNYTAMR's Avatar
Default biggest stall i can run and still spray?!
...... new thread with poll
Old 06-09-2005, 10:45 AM
Ragtop 99's Avatar
You can go to 3600 - 4000 stall depending upon the design. For example in the Yank line, I would look at the SS series but not the YTP since you are spraying 150 shot.
Old 06-09-2005, 02:14 PM
what about on a 200-250 shot i will eventually run.. maybe a ss3600... i mean i can always strap on some taller tires then the 28 inchers i got.. maybe 29-30 inch
Old 06-09-2005, 02:20 PM
LS1 BU's Avatar
I run a PT4000 stall and gonna spray a 200 shot. I made 428 rwhp with a locked convertor. I made a run with a 150 shot and a unlocked convertor and made 567 rwhp with a 10.0/1 AF.
Old 06-09-2005, 09:54 PM
Ragtop 99's Avatar
If you are serious about the 200 shot, get a dedicated nitrous converter.
Take it down the track and let us know what happens. With 7000 rpm shift points you may be ok, but 200 shot will stretch a YTP converter out too much for a motor shifting at 6500 or below.
Old 06-09-2005, 10:43 PM
Spdmini's Avatar
yeah your gonna want a converter w/ a anti-ballooning plate or it will strech out to be a 5K+ stall.
Old 06-10-2005, 07:26 PM
zeeya's Avatar
Im running a 4200 stall here
Old 06-10-2005, 10:24 PM
hmm... with a antiballoning plate it will hold its motor shift extensions when the nitrous hits.
Old 06-10-2005, 11:01 PM
gator's 99TA's Avatar
my st4000 and 120 wet shot put me at the limitor way before the finish line about 5000 rpms it stalls at pushing through the convertor.
i hear the SS4000 will hold a 150 shot no problem.
Old 06-11-2005, 01:58 AM
JZ'sTA's Avatar
I would do a 3600 or 3800 Yank.
Old 06-11-2005, 04:47 PM
mrr23's Avatar
i use the PY3400E and use 200 shot.
Old 06-11-2005, 05:25 PM
LS1 BU's Avatar
I shift at about 6800 rpm. I have a G5X-3 and it peaks at 6450 and hold the same power to 6900rpm. I thought the PT4000 has a anti balloning plate??
Old 06-11-2005, 08:22 PM
Retired Street Racer
Matt D's Avatar
TCI ssf 4000 can handle a 200-250 shot.
Old 06-11-2005, 09:54 PM
formulajunky's Avatar
Question What should i do then
I am using a 150 shoot with stock convert as of now i have a 98 Formula A4 3.42 rear gears and stock motor no exuast work yet i want a good 2100 to 2400 launch can i do it what stall should i get and Where can i go to buy it thanks for any help guys I also redline at 6200
Old 06-12-2005, 08:54 PM
Ragtop 99's Avatar
Don't waste your $$ on anything smaller than a 2800. You don't want to spray at 2100 rpm and that won't do jack for you NA. There are several good converters in the 2800 - 3300 range that will work well for you.
Old 06-12-2005, 09:02 PM
dont spray below 3000 rpms! cylinder pressure will be enough to break the motor.
Old 06-12-2005, 09:21 PM
So i should go with a 3200 Stall
What should i look for like Anti Ballon and stuff like that anything i need and dont' need not very smart when it comes to converters help would be nice before i go buy it, and i spray from 3k to 5700 with WOT window Switch
Old 06-13-2005, 02:53 PM
Matt D's Avatar
i have my converter for sale if you want it. it is a tci ssf 4000, and has anti-balooning plates, and only 10 passes n/a, and none on spray. let me know if you are interested, via PM. thanks
