broken valves?/
broken valves?/
What are some symptoms of a broken valve or bent pushrods or any problems with the heads other than the gaskets. Im trying to figure out why my car is running like ****! Its eating up gas like a **** and I have no power where I used to. I have no low end tq anymore. 3rd and 4th gears are weak, when they used to be very strong. Before it was tuned, it still ran good, I got it tuned a few days after and ran great. Now, 6 months later its running like dookie. A little help would be nice.
Nino
Nino
Bent a valve in my IROC, and the symptoms described in your first post were what it was doing, plus the ticking/clicking noise. Have you over revved it, what makes you think it's in the valvetrain? Might be time to take off the valve covers and take a look
Not going to say definately valvetrain, but if everthing else has checked out, that'd be my next stop
ive checked the driver side and it kinda looked like one of the pushrods was slightly bent...very slight. I still need to check the passanger side. I dont think that Ive over reved it. I wont know till i finally pull the heads, but I need to get some gaskets and studs first.
