Is my fuel pressure right
Old 06-08-2005, 08:40 PM
Joe-Ls1's Avatar
Default Is my fuel pressure right
My fuel pressure is 60psi while normal drive when i get on it it drops to 56psi is that the normal operation psi.
Old 06-08-2005, 08:59 PM
ABeasst's Avatar
thats what mine does
Old 06-08-2005, 09:55 PM
Ferocity02's Avatar
Normal!
Old 06-08-2005, 10:35 PM
chris77's Avatar
makes me wonder, mine is at 55psi is that to low.
Old 06-08-2005, 11:49 PM
Joe-Ls1's Avatar
well i want to install a 200 shot of nitrous and i have the 26lb injectors will 36lb injectors help with a 200 shot of nitrous i also have a stock in tank pump with a vortech in-line fuel pump.
Old 06-09-2005, 10:32 AM
Spenser309's Avatar
depends if ur running a wet or dry shot. Dry shot you need the injectors actually even bigger ones maybe. Wet shot dont worry about it all your extra fuel is supplied with the nitrous because a wet shot injects nitrous and fuel.
