speed is off
Old 06-09-2005, 09:56 AM
obZidian's Avatar
Default speed is off
hey, just wanted to see wat transrev/mile numbers is accurate for my 98 speedometer, with 3.23'z, a4, and with 245/50/16r to read right? would also like the vss number as well.
I noticed that in the speedometer section of hp tuners, the box'z that say gear and the one next to the transrev/miles both are ghosted out and i cant enter any figures in it. MY original tire/ gear calcualtion was 7.71. I changed to 7.91, hoping that it might help but the speedometer is still reading about 5 miles higher than wat the hp tuners scanner is telling.
thanks!
Old 06-09-2005, 11:29 AM
12secSS's Avatar
You setting needs to be 7.94. Those other values are incorrect for your tire size and gear ratio.
Old 06-09-2005, 10:58 PM
obZidian's Avatar
sorry, i have it on 7.94..
The calculated gear box ALWAYS says "n/a".
The box by the the transrev/miles is also ALWAYS on "n/a".
vss pulse is on 101618.770780856
vss pulse rev is on 40.0000
vss pulse output is also blank and i cant wrire anything on it like the gear box and the "transrev box"
wat is up fella's?
thanks!!
Old 06-10-2005, 10:17 PM
soundengineer's Avatar
tire / gear
7.9411764705882352941176470588235
vss pulse/mile
101620.2174
pulse /rev
40.0000
trans revs/mile
2540.608902
auto scale transmission tables = yes
thats what I got when I plugged in the #'s...
might just need to be more specific on the 1st #...
I just used the windows calculator and did a copy and paste...
