What would you do? Blower cam and H/C questions
Old 06-09-2005, 12:14 PM
Cajundude's Avatar
Default What would you do? Blower cam and H/C questions
This is for an 02 Vette (for labor questions):
Is there a blower cam made with a nasty lope to it? I want to do heads/cam now and I'm 98% sure that I will go with a blower later but I really want a nasty sounding cam.
What is the power difference between, let's say, a G5-X3 or the MTI R1 or Y1 cams and a regular blower cam? Are we talking 10 hp or much more?
If we are talking a big difference I will probably just install a blower cam when the blower comes and the R1 or Y1 now with the heads.
How many hours extra work would I be looking at if I do end up swapping cams with the blower install? Should I get the QTP two-piece cover now if I go the swap route? How much time will that cover actually save to justify the cost?
Can you run a blower cam for a while without a blower?
Thanks!
Old 06-09-2005, 01:11 PM
SiL3NtXWS6's Avatar
The whole point of a blower cam is to not leak air out. You don't want any overlap (lope). Bigger cams on 114/115 LSA's will still lope, but nothing like something ground on a 112.
It's not hard to change cams. I wouldn't waste the money on a QTP cover unless you do a cam swap everyday.
You can drive a blower cam with no blower..
Old 06-09-2005, 01:57 PM
conan's Avatar
See sig. My cam sound's realy good right now. I dont have the blower on yet so I'm sure the sound is going to change with that addition. Sil3ntxws6 said it , min 114lsa and you want more exhaust lift and durration than intake. Heads look into a bigger combustion chamber to loose compression. You can check MTI's 6.0L, AFR's 225, Or TEA makes great heads too.
Old 06-09-2005, 02:11 PM
Cajundude's Avatar
Thanks for the info! Not sure about the F-body but you have to drop the whole rack to get the pulley off on a C5 to change the cam. That is the thought about the QTP cover. You don't have to pull the pulley to change out later.
$550.00 is an awful lot to save a few hours labor, plus you can't use a double roller with the cover either. Maybe I'll just pull the rack twice.
Old 06-09-2005, 04:26 PM
narcszm's Avatar
pulling the rack is a LOT easier the second time. Hint: unbolt the ABS unit and it's 100% easier to do. disconnecting the pump is still a time sink, though, what with the fluid oozing everywhere and waiting 30% of it to go into your catch container.
It's the lobe separation angle that makes a car lope. So, if you want a blower cam to lope, bring in the intake and exhaust duration and get a more aggressive lobe ground into the cam. (like an XE-R) An XE-R lobe at 220 will get about as much air into the cylinder as a 226 XE lobe. So, buy the shortest-duration XE-R cam you can find, and go for the narrowest lobe separation angle that still has zero (or 1-2°) of overlap.
That'll give you the power out of the blower and give you the tell-all idle you are looking for.
Old 06-09-2005, 04:48 PM
Blown 98 Z's Avatar
236 / 240 601 / 608 114 +4 Comp Cams XER
D1SC Procharger
Sweet Idle.
Don
Old 06-12-2005, 05:21 PM
Cajundude's Avatar
Thanks for the answers! Exactly what I was looking for.
