Quiet PUMP
Quiet PUMP
I have to install a phamspeed to run 8psi with 42lbs injectors. I have been looking around and wanted to know the best quietes inline pump available?? How much harder is it to run an intank pump? Thanks..... same questions for the intake as the inline.....
thanks guys
thanks guys
Just opt for the racetronix intank set up. Its a real simple and easy to do swap and should be able to handle 8psi and 42's easily. Its very quiet and priced pretty good. I've been happy with mine.
Install is REAL easy if you cut an access panel out to remove the pump.
J
J
I agree!
An intank pump will be easier to install than an inline because its just a direct replacement. I went with Racetronix also. It is pretty quiet, louder than stock but you can only hear it when you prime the pump before starting. Easy install too with the trap door. Mine took about two hours to complete.
