9" fill plug hitting gas tank
I have the moser housing and strange CS and my fluid fill plug is rubbing on my gas tank, it is starting to scratch material away. I have the 99 plastic tank, and I am pretty sure it is the tank, not a gaurd but Im not totally sure. BTW I have the eibach pro kit springs
Anybody have a similar issue, I might grind down the top of the plug a little but thats the only thing to grip and screw it in/out with.
I was thinking about using a torch to heat the tank plastic a little and bend it in some to clear the plug. Ha I am just joking with you, Im not going to try that, so write any other ideas you might have
Originally Posted by badpewter-z
i believe most that have the fill plug will have this issue i wish thats one option i didnt get best bet is to grind down the plug . its easier to fill it from the side anyways
