Do I need a new driveshaft with a Moser 12 bolt?
Originally Posted by RAMAIR57
Just wondering if the stock driveshaft will work, or if I need a different one to accomodate it
There is Zero way to know untill you bolt the rear up, load the suspention and test the slip traval of the drivershaft. Less then 1/2" and your in trouble.
1350 Conversion U-Joint (Napa Part # 447x ) pressed onto driveshaft.
- Axle Bearings Pressed on (Any local auto shop can do this usually): They do not come pressed on because you need to swap the brake backing plates from the stock unit to the new unit and then press the bearings on (This swap is a few minute swap).
- Generic 3" muffler clamps to relocate sway bar.
thats what I used and had no problems.
if the stock aluminum driveshaft fits, Im just wondering if itll hold up to an over 400 rwhp car with a pretty decent launch on dr's (no slicks, but a pretty hard hitting converter). Anyone give me an answer I can be safe with?
That's why I made the switch to a Denny's Nitrous Ready Driveshaft... better safe than sorry. I'm only running about 390 rwhp or so, but I'm also hitting the drivetrain with 6500 rpm clutch dumps on slicks.
hmm, I better get one just in case then. Will an aftermarket aluminum be sufficient for what Im running. I hear they are smoother, etc at higher speeds; or, should I make the jump to a steel driveshaft
