Full throttle switch??
Is there an electronic full throttle switch that works off of the cars wiring? I had a manual one on the throttle body, but does not look very clean. There must be one that works off of the throttle position sensor.
Thanks
Thanks
Closed ex-Sponsor Account
We have a tps switch fully potted water proof,http://www.nitrousexpress.com/Instructions/tps.pdf
Also found this style if you want to save a little $$$.
http://www.nitrousoutlet.com/outlet/...le_bracket.pdf
Ricky
Ricky
Oh yeah Thanks Rick.I completely forgot about our custom built micro switches.That will save you some money if you do not have the money for the TPS.
http://www.nitrousoutlet.com/outlet...tle_bracket.pdf
