Master Blaster Purge System?
Does anyone have, or know someone that does, the Master Blaster purge from Dynotune? What does it do over there regular purge? It looks huge. Also, is Dynotunes purges pretty reliable? Thanks.
LS1TECH Sponsor
The MasterBlaster purge uses a 250HP solonoid versus our regular purge which uses a 175HP Solonoid. Our solonoids are top quality and our customer service cannot be beat. This purge is louder and huge!
http://www.dynotunenitrous.com/store...p?idproduct=45
Dean
Dean
So basically your just shooting more nitrous into the atmoshere? I think I will probably just get the standard purge. If anyone has any pics of videos of the Masterblaster, I'd like to see them.
Josh, from watching your purge compared to others with a regular purge, how is it different....as in worth getting? To me it seems you would waste more nitrous because of the bigger noid.
Originally Posted by 150shotWS6
You should make a vid. so people can see what its all about!
LS1TECH Sponsor
DynoTune Purge video
Here is a video of the standard dynpotune purge kit in action. http://www.dynotunenitrous.com/store...ette_purge.wmv
Your welcome to go to the webpage at www.dynotunenitrous.com and checkout all the purge kits.
Cheers
Dan
Cheers
Dan
Cheers
Dan
Cheers
Dan
It really looks like that(probably a cold day)! Damn Cant wait to see the master!
Cheers
Dan
Cheers
Dan
umm if this is the one I am thinking of, why can't it be used with the "V" purge nozzle? would it work with the Twin Outlet Purge kit ?
I used the master blaster purge with the v nozzle and the plastic line lasted about 2 purges. I then upgraded to braided line and drilled out the outlet holes of the v nozzle (so it would flow better) just drilling the nozzle out made a huge difference in the size of the v
8 second mod
I have Both. i use the smaller one in cold weather and the Masterblaster in hot weather. reason being in the hot, i get bottle psi down faster, and the smaller one in cold weather because i have no bottle heater i rely on my hot box and a torch.
both are great kits. Mix Dynotune purge with a dynotune psi gauge, and it looks sick!!!
I will try to get a pic of how i did mine.
the dyno tune parts are very nice.
Oh yhea, with the master blaster, It is a head turner!!!!!!! its loud!!
8 second mod
not realy, you can just touch the botton quick, and it lets out a little bit.
but say its 95* out, and Bottle press is 1200psi. you get to the line and have to purge to 950 psi. with a small purge it take for ever, with the master blaster you can get to your desired psi faster. no matter what if your at 1200 and have to get to 950 the Nitrous waist will be the same no matter how big the purge.
some people purge to look cool, but the biggest thing a purge is for is to ge the bottle to your disired pressure.
So you're saying purging is to mainly get your PSI lower before you spray? I thought the main purpose was to get the line full and ready to spray.
