Throwing a P0751 for the trans...why?
Old 06-10-2005, 07:53 PM
Retired Street Racer
Matt D's Avatar
Default Throwing a P0751 for the trans...why?
The code is for (Solenoid "A" Performance or Stuck Off). I threw the code before, and when it was under warranty, I had it fixed about a year and a half ago. Now it is throwing the code, and when i am on the highway with the cruise set at 80, the RPMs are jumping up and down from 3000 to 3400 and back. I figure that is the converter unlocking and locking. Any clue of what it could be? I have a TCI ssf 4000 converter, Trans Go shift kit, and a 4.10 gear. Thanks.
Old 06-10-2005, 08:01 PM
rufretic's Avatar
I get the same code. I've been looking for an answer for a while but haven't found a real fix. I'm going to try changing the solenoid but I don't think its the problem. Its worth a shot though.
Old 06-11-2005, 05:41 PM
black 2001Vette,Nightmare's Avatar
My Vig 3200 has just recently started drifting in and out of lock-up mode, like yours. I'm wondering if it could be the lock-up solenoid?
Gonna take it in to RPM Mtrsprts soon and see if they can resolve the issue.
Good luck, and post your eventual fix.
Old 06-11-2005, 05:50 PM
electricz28's Avatar
Same here but the code cleared itself and this was a week after the rebuild.
Old 06-11-2005, 06:26 PM
Matt D's Avatar
i have already had the solenoid replaced before. could it be the same one again?
Old 06-13-2005, 02:48 PM
Matt D's Avatar
well, the solenoid went bye bye, and it is stuck in 3rd gear. time for a th-400!
Old 06-13-2005, 02:52 PM
rufretic's Avatar
Why, can't you just replace the solenoid? Or do you just want to up-grade to a stronger tranny?
Old 06-13-2005, 03:18 PM
Matt D's Avatar
i don't think it is the actual solenoid causing the problem. i just had it replaced around a year ago, and i don't see them blowing every year. i think the problem is electrical, but who knows. if it is gonna cost a lot to have it replaced, and still have the same problem, then it will just be better to go to a 400 and not have any problems.
Old 06-14-2005, 01:07 PM
rufretic's Avatar
Someone recomended to drive in 3, on the camaro its D, instead of over drive. I tried it and the light went out after a day of driving. It hasn't come back on yet so it seems to be a good temp fix. I think it helps because the converter locks up at 30 instead of 40. I'm going to put a shift kit on and change the solenoid while I'm in there so hopefully I won't get the light again.
Quick Reply: Throwing a P0751 for the trans...why?
