MSD WS Pill question
I broke one of my msd pills and got to thinking, maybe I can make pills. I got the trusty ohm meter out and started measuring, here's the results:
6000rpm = 1616 ohms resistance
6200rpm = 1650 ohms
6400rpm = 1680 ohms
6600rpm = 1714 ohms
6800rpm = 1745 ohms
So, it seems that they are just resistors? I could just put a resistor in that calculates to my desired RPM? Am I missing something or would this work? I don't know if there is a variable voltage to contend with or if a standard formula would work? I am going to do some backwards math to see if I can figure that out or not, but help is certainly needed.
Edit: Yes, I know, I have no life.
6200rpm = 1650 ohms
6400rpm = 1680 ohms
6600rpm = 1714 ohms
6800rpm = 1745 ohms
Originally Posted by Robert56
Thanks BMN, I figured someone would know. Now is the fun part, searching the web.
http://www.corral.net/tech/powerplant/arm/
shows a homemade box. I don't think his math looks rite. Not sure what cyl mode and to lazy to do research on this cool sunday.
Yea, I think your right on his math, however, it may be correct for non ls1/ls6 type motors because we run the MSD in 4cyl mode (looks as though his jumper wires are not cut). Also, his math doesn't correspond with res reading on the pills I listed above. That doesn't mean using a pot won't work. Just some details to work out. I am going to measure some low rpm pills and see if what he say's is correct. I've got a couple 2.2k resistors right now and will test them compared to his math using my car and a test light to see what rpm it comes on. We are getting close. I do like the idea of using the variable resistance.
is the math correect? It should work for any setup right, the only difference is he is running a ford, which isnt the 4 cyl setup, so all we would have to do is cut the loop on the msd switch, and this "box" should work regardless right? After all, you cant beat the $5.00 price tag of making it. Let me know asap, I might be heading to the old radio shack and making one of these before I get my setup, while it is fresh in my mind. Thanks
Correction, I had my ohm meter at wrong setting, here is correct numbers:
MSD Pills:
6000rpm-4.57k res
6200rpm-4.78k
6400rpm-4.99k
6600rpm-5.21k
6800rpm-5.43k
So the backwards math (suggested math in link above) of established values works out to:
4570 + 1000rpm = 5570rpm (6000 msd) Difference 430rpm
4780 + 1000rpm = 5780rpm (6200) 420rpm
4990 + 1000rpm = 5990rpm (6400) 410rpm
5210 + 1000rpm = 6210rpm (6600) 390rpm
5430 + 1000rpm = 6430rpm (6800) 370rpm
We are closer, but there seems to be a discrepantcy. The math is off by 430rpm to start and looses 10rpm at each level as you go higher. This pattern means something if it can be figured out. Something else is at play here? We'll see.
MSD Pills:
6000rpm-4.57k res
6200rpm-4.78k
6400rpm-4.99k
6600rpm-5.21k
6800rpm-5.43k
Maybe I have it. Ohms law: It takes 1amp to push 1 volt through 1ohm of resistance. Now if you change the percent of anyone of those values you'll get differant results (simple math). So in conclusion, we need to know the amperage (or rather wattage) that MSD is sending through the resistor to get an accurate formula (a little more tuff math). Thats all a resistor does is change the output from the input. Any electrical Engineers floating around that can help us, if I can't figure it out?
Ok, for those who are following my tangent, here are some more numbers.
MSD Pills
6000rpm = 4.57k ohms or
12volts / 4.57k ohms = .0026mA (signal leaving resistor)
6200rpm = 4.7k ohms or
12volts / 4.7k ohms = .0025mA
6400rpm = 4.99k ohms or
12volts / 4.99k ohms = .0024mA
6600rpm = 5.21k ohms or
12volts / 5.21k ohms = .0023mA
6800rpm = 5.43k ohms or
12volts / 5.43k ohms = .0022mA
Then using suggested math:
5k ohm resistor + 1000rpm = 6000rpm (or desired rpm), however,
12volts / 5k ohms = .0024mA
5.2 ohm resistor + 1000rpm = 6200rpm, however,
12volts / 5.2k ohms = .0023mA
5.4k ohm resistor + 1000rpm = 6400rpm, however,
12volts / 5.4k ohms =.0022mA
5.6k ohm resistor + 1000rpm = 6600rpm, however,
12volts / 5.6k ohms = .0021mA
5.8k ohm resistor + 1000rpm = 6800rpm, however,
12volts / 5.8k ohms = .0020mA
So, we can see the differences. Does this mean that the pot won't work, no. I think it'll work fine, just the suggested math (link) doesn't work for single resistors and/or compare with known values (read: msd). The math for the MSD pills should work fine for making individual pills and be right on. Maybe someone can spot why things don't jive. I think I am going to make one of the rheostats (variable resistance) when I get time and use a single res for now.
MSD Pills
shouldnt this be 6400 rpm?
and i think you want to measure current before the resistor so you know how much your attenuating with your msd pill
It's not the current that they effect. The resistors change the frequency of the local oscillator inside the circuit. It then uses comparators to see if it above or below the freq for the on and off then uses simple logic to switch the N2O out leads. + goes - and - goes +.
I didn't measure current at msd because just using a constant 12v on each system/idea and they should follow with the same results.
resistors do not change frequency at all in this case it steps down voltage. the only way a resistor can effect frequency is if it's used with a capacitor then it acts as a filter. not neccisarily changing a freq but removing unwanted ones. if you hook a tach signal up to a o-scope it's going to show you a square wave of 12v p to p hook a resitor up to it and you will see your wave drop in voltage depending on the current.
