play in the rear end yoke
i can turn my back yoke in the rear end about 1/4 turn is this bad. it has only happened since i put the locker in. i can notice it when shifting from park to drive and reverse. is this something i can fix? is it bad? am i gonna brake something?
hey yah problem here too but with the stock rear end. Driveshaft will turn a 1/4 inche too. If i jack up the rear the driveshaft turns a 1/4 inch then the tires will start moving. I will clunl too when put into reverse or drive, and i can feel it when it shifts 1-2.
same with mine
i've got a m6 and i get a clunk when i shift from 1-2
Probably normal. When you turn the yoke back and fourth you're taking up space such as the backlash, space between side and spider gears, space in between the axle splines and side gears, etc.
