T-REX question
Old 06-12-2005, 05:08 PM
Formula-T/A's Avatar
Default T-REX question
Hey guys I have a 230/224 .575/.563 cam and I was thinking of going with the T-REX cam.My car is a a4 with no stall,will this be a problem?
Old 06-12-2005, 05:20 PM
SOM98TA's Avatar
yeah its a problem.
Old 06-12-2005, 05:43 PM
what kind of problems?
Old 06-12-2005, 05:44 PM
LS1Tech Sponsor
hellbents10's Avatar
You are gonna need a lot of stall like 4000 or better and a really good tune and some gears. Do a search and you will see the light.
Old 06-12-2005, 05:46 PM
thanks man.
Old 06-12-2005, 06:00 PM
blkZ28spt's Avatar
You need a converter. Minimum to get any real use out of it would probably be ~4k stall speed, 3.73's and a good tune.
Old 06-12-2005, 07:31 PM
8banger's Avatar
Wow, running a TR230 without a stall? I don't even want to know what that'd be like off the line. As everyone else says, you NEED a stall and gears. Without a stall, you car would barely even run/idle with the T-Rex. It's a badass cam, but it definitely needs other mods with it to be effective.
Old 06-12-2005, 09:52 PM
35th SS's Avatar
better get the other mods first like everyone says before and put the trex in there.if I was you go with a 4400 depends if you d/d drive it or not.you can do a search on that one.good luck.
Old 06-12-2005, 10:21 PM
Josh's Avatar
I don't have any experience with A4s, but I ran my T-ReX with stock gears for more than a year. Obviously, that wasn't ideal, but I did it, and I still enjoyed the cam.
Josh
Old 06-13-2005, 05:42 AM
Jimmy P's Avatar
My buddy is running a t-rex with 2.73 gears, but he has a 3800 stall . Ran a 12.0 @117 i believe, with a 1.7x 60ft. It could realy use larger gears though.
Old 06-13-2005, 06:31 PM
Its not that bad of the line,I have 3.73 gears and it spends the Mickey Thompsons till about 3,100rpm in 1st. I know I need a stall but its a daily driver and I really dont want to go over a 3,500. Thanks for the advise guys
Old 06-13-2005, 11:06 PM
8banger's Avatar
Do what I did...pick up a nice 3400 stall.
Old 06-14-2005, 09:03 AM
koniu77's Avatar
i would get little more then 3400 for a t-rex, more like 4400
Old 06-14-2005, 11:29 AM
Bryan @ Speed Inc.'s Avatar
i think you'd be fine if you had a 3500 stall w/ a 3.73 gear. and to the guy that said he ran the cam w/ his m6 car w/ stock gears for a year.... manual cars are much easier to deal w/ big cams. an automatic you can't jsut rev the motor up a little higher and slip the clutch a little more. stock stall + big cam = BOG!
Old 06-14-2005, 01:53 PM
KGSloan's Avatar
really you should consider just getting a stall for the setup you have.
i ran the tr 230/224 for a while and it can run some killer times (mid 11's at 119 mph in my car). of course i had all of the supporting mods to go with it. which is essential to running fast times.
put a stall in the car and it will be a completely different animal.
Old 06-14-2005, 02:18 PM
blkZ28spt's Avatar
Trex needs more than a 3500 stall. Hell, my MS3 needed more than that to show any of it's potential. You could get away with the Trex on a 3500 but it would be stupid, IMO, to put a Trex on a <4000 stall.
Old 06-14-2005, 06:50 PM
Thanks guys,I guess I will keep what I got and give a stall a try.
Old 06-14-2005, 09:54 PM
8banger's Avatar
Good...that really is an awesome cam.
