Stock M6 Trans rating
Originally Posted by Abdullah
i think they are rated from the factory at 450 lb.ft but i can see from many forum's members that this tranny with proper clutch can handle much more.
Thanks for the info.
Damn!! You are a long ways away....Kuwait??
Transmissions do not care what HP you have. They only see torque. The synchronozer issues also have nothing to do with HP( OR torque) they only see RPM differential. If you drive it sanely, it will last quite well as was stated above. If you insist on attempting wheel stands or allowing the wheels to hop under totque, you will trash more than just the trans.
