pass n gear problum on my Z
What us old timers used to call passing gear. Just the tranny downshifting when you floor it.
Need more info on what rear end gears the car has and what speed you are going when you are flooring it. There are tables in the pcm that control when it will command a downshift based on mph.
it does not hit the rev limiter, i installed a hypertech programmer to rev at 5900 n it only gives me 5500rpm. lets say im at a 30mph roll, i floor it n it down shift to 3rd instead of 2nd. will doin an ls1 edit help it?
