Northwest Members - Cam is in, springs are done....
93TAWicked1
06-13-2005, 08:56 PM
WOW what a PITA :) The vette is still easier to work on but that steering rack and the HOOD is a PITA. Next time I do any substantial work on the car I am having a friend help me take off the hood first.
The springs were a breeze using the TDC method although the Larry's tool has some cheap hardware the nut stripped the threads and popped off still don't know where it ended up, fixed the threads on the stud and bought a stainless nut and washer I recommend doing this before even using it.
The JPR tool I borrowed would not go in so I tested a lifter a couple of time with a pushrod and they were stuck up pretty good. Did the Russian roulette method figuring if I drop a lifter I'll just order a freaking stroker shortblock ;)
So now I have to get the timing chain lined up which is a bitch with the car in the air and the hood in the way, but once I get that in and the balancer back on it should be easy the rest of the way, now that I've said that it will be a bitch but oh well. Hopefully I'll have her running by tomorrow and at the track on Friday night with Chris's drag radials!
HMMM now I better get to work although its tempting to go back down to the garage and finish the car......
Mikey 97Z M6
06-13-2005, 09:01 PM
Awesome dude!!! :)
BTW, I have Friday off of work!!! :)
Mike
93TAWicked1
06-13-2005, 09:05 PM
SWEET looks like your going to be going to the track with me. You can run the vert if you want Jyla is going to be out of town. :devil:
Nathan
06-13-2005, 09:07 PM
what a bastard.
ah well.
i have 2200 miles on my car now
93TAWicked1
06-13-2005, 09:10 PM
what a bastard.
ah well.
Like I said before you have alot of catching up :) Figure by next spring there'll be a clutch and 125 shot on it. If you can beat that then oh well I'll just have to bow down.
I'd still rather drive your car on a trip than mine though!
I'd offer you my stock cam and springs cheap but you already have them in your LS2 :)
Mikey 97Z M6
06-13-2005, 09:12 PM
LOL,,,, sounds like an excuse to go have some fun to me!!! :)
Mike
Nathan
06-14-2005, 03:17 AM
when i was in nevada last week, my car didn't feel as good.. i was tempted to put some nitrous on it then!
stupid 4000'+ elevation
feels stronger now that i'm back home.. i think the engine may have broken in...
also i averaged 25.1MPG on the way there
and 26.2MPG on the way back
574 miles each way.. and it was pretty comfy
:drive:
i won't race you anymore though.. eventually i need to hear that cam
:eek2:
WAHUSKER
06-14-2005, 07:48 AM
COOL! Sounds like we might have another 11 sec car in the NW soon. :) So Mr "I'm not going to mod this one", which cam did you put in? Looking at Erics Vette, it looked like you have to pull the ABS module. I take it that is not the case?
As for the Larry tool, I agree, good idea, weak ass hardware. I put a big washer on it & that helped some. And heat your balancer up in the oven at 250 for 20-30 minutes & it will slide on to the point where you can use a bolt to tighten it down.
Rockin C Racing
06-14-2005, 08:10 AM
Bobby - Which track? PIR is closed this weekend for the champ cars.
93TAWicked1
06-14-2005, 12:02 PM
The ABS just need to be unbolted then you can move it up just a tad and the steer rack will clear other than that it doesn't get in the way. You unbolt the power steering assembly and braken from the head\block then you can get to the two lines going into the steering box with an 18mm flare wrench and then take the whole thing out. Again easy just time consuming :)
Went with the Stealth II, Visceral help me make up my mind I like the idea of more power with stock idle and driveability :)
93TAWicked1
06-14-2005, 12:04 PM
Woodburn, unless we have a bunch of people showing up at PIR I think I'm pretty much done with that place. You can really feel the difference in the tracks when shifting into second. PIR is like a skating rink while Woodburn even when you spin you can feel the tires "biting"
Plus 4 runs a night at PIR compared to 15 a night at Woodburn :drive:
WAHUSKER
06-14-2005, 01:12 PM
The St II should be an intersting combo with those headers! Can't wait to see your new timeslip. What did the headers do for you?
narcszm
06-14-2005, 08:09 PM
Congrats. how many times did you smack your head on the hood latch? I lost count around 20 or so. ...I hear those drag radials like to be launched at 5499 RPM. ;)
