Grinding letting out clutch in 6th
My H/C GTO has only 6K miles and has just started to grind when letting out the clutch after shifting into 6th. The grinding can be heard and felt in the shifter, and the gear will not engage (just grinds) When I push in the clutch, shift back to 5th, then try again sometimes it goes into 6th fine.
I searched the archives but it seems most people have problems grinding when shifting into gear. Mine shifts fine but grinds when I let the clutch back out.
Any ideas? I'll probably be taking it back to the dealer but can imagine the crap they'll give me for the "modified" engine and aftermarket shifter (GMM Ripshift).
Could it be shifter stops set incorrectly? synchros?
I think the reason why it grinding when you let out is because its not all the way in gear and when you let out it's grinding the teeth on the edge of the hub for 6th gears.
The reason why I say this is because I just got mine rebuilt and my 6th gear hub was bad. The teeth get slanted on a hub that moves 6th gear into position.
The slider keys were broke in mine and would'nt go into any gear.
