Anyone Else Having Problems Sealing...
Up their head studs??
I have anti-freeze in my spring area again, but on the other side of the motor!!!!
Oil is clear, just under the valve cover.
Originally Posted by Muffracing
Do you have scerw in rocker studs? I had to use sealer on mine.
I had no problems until I switched to head studs. Same heads, then and now, last fall, it was on the pass. side , now its the drivers. And no I didn't swap heads, as the holes in front only allow me one way to install.
