Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
cutting exhaust pipe
Old 06-14-2005, 05:25 AM
HellRaiser's Avatar
Default cutting exhaust pipe
Whats the best tool to use to make clean cuts on 3" 16 gauge stainless steel pipe? I used a pipe cutter before but it tuff to use that on the bends.
Old 06-14-2005, 06:52 AM
Brains's Avatar
I use a 14" chop saw, works like a champ.
Old 06-14-2005, 07:43 AM
jdustu's Avatar
yeah, i need to get a chop saw.....other wise an angle grinder w/ cut-off wheel will work, that's what i use.......
Old 06-14-2005, 09:28 AM
Camaro_Zach's Avatar
a portable band saw will work too.
Old 06-14-2005, 09:49 AM
MrDude_1's Avatar
if you're doing this on a bench or in a shop a chopsaw is best.. followed closely by a REAL bandsaw.
if you're doing this on the car, a right angle grinder with a cutoff wheel, or a sawzall works good.... if its a really tight space, you may have to resort to the old disc-blades-on-a-chain style tube cutter.
Old 06-14-2005, 08:13 PM
redbandit98's Avatar
i alwyas use a grinder...it sucks but im too cheap to buy a sawzall..i wish to hell i could afford a plasma cutter...
Old 11-18-2005, 12:02 PM
GuitsBoy's Avatar
You can also find 4 headed pipe cutters that make short work of cutting the exhaust. Oterwise use an angle grinder.
Chop saw is really the best, but out of reach for many folks. Ive used a bandwaw, but its always tought to get it started.
Old 11-18-2005, 04:26 PM
1fastWS6's Avatar
You can get a chop saw at Harbor Freight for like $50, that'll work the best. You'll just burn up blades using a sawzall on 304 stainless....it's REALLY hard ****. I use my disc grinder and cutoff wheels mostly though.
Quick Reply: cutting exhaust pipe
