Please help! Need to get Noids Checked
Ok I have a TNT F-1 kit and Im wanting to get my noids checked out and or serviced and I need some in regards to removing the fuel noid. I am tapped into the Shrader valve or were it used to be. I have coming off the shrader a single hole purge/gauge adapter and hooked up to that a FPSS a hose and obvioulsy the fuel noid. My question is can I just cap the shrader or do I have to buy a whole new shrader valve. Basiclly I need to know the best and safest way to remove the fuel noid and stop fuel from leaking. This is my daily driver. Thanks!
Closed ex-Sponsor Account
Both option will work nicely. A -4 cap is in my opion a better choice. Alot easy to just throw in the glove box and no its there with out loosing it, That shrader valve is always getting lost or miss placed. Not to metion you need a special tool to put back in. Then there is a chance you forget to pull it out when the noids return. Rep -4 cap all the way.
You sending them back to TNT. Tell David I said Hello.
Ricky
Ricky
Yeah I just found out that a 4AN cap will work. Im definitly not going with a plastic one. A Russell type cap would work best right? Someone told me that GM says not to resuse the stock Shrader if you eake it out! Is that true?
