FS:Alpine Midbass speakers and SPS-170A
For sale are the new SPX-17MB midbass speakers from Alpine. They are 6.5" speakers.
RMS Power 75W
Frequency Response : 30 - 4kHz
Impedance (Nominal) : 4 ohms
Mounting Depth (Woofer) : 70.8mm / 2.8"
Mounting Diameter (Woofer) : 132mm / 5.2"
Coil Height (Hvc) : 16.7 mm
Compliance (Cms) : 1.44 mm/N
Cone Area (Sd) : 132 cm
D.C.Coil Resistance (Re) : 3.6 ohm
Electrical Q (Qes) : 0.50
Equivalent Suspension Stiffness (Vas) : 34 Liters
Force Factor (Bl) : 4.9 T-m
Free Air Resonance (Fs) : 31 Hz
Frequency Response : 20 - 6kHz
Gap Height (Hag) : 5 mm
Inductance (Le) : 1.7 mH
Linear Excursion (X Max) : 5.85 mm
Mechanical Excursion (Peak-to-Peak) : 16 mm
Mechanical Q (Qms) : 6.8
Moving Mass (Mms) : 18 g
Sensitivity : 86dB
Total Loudspeaker Q (Qts) : 0.46
These have only been in the car for about two weeks. All the crossovers and wiring comes with them. I have decided I want to buy a 10" sub so I have no more use for these. I am asking $150 + shipping. I can also accept credit cards through my business.
Please email me with any questions or interests at Jraad1@comcast.net
(I have decided to keep the alpine Sps-170a's)
RMS Power 75W
Sensitivity : 86dB
huggerorangss
Give me a week or so to finish getting all of my system installed. If I dont like the way it sounds (spx-177r in the front doors + 10" sub in rear), we'll discuss then.
Alrite GPz1100, I'll be waiting. Also, Price is down to 120 + shipping. I don't want to buy my sub until these are gone and until then, I'm stuck with just two front speakers.
Good luck with those.
I ended up getting a set of coaxail type R's (full range) for the sail panels instead. I thought the rear would benefit more from midbass/midrange fill . Got 'em HPF'd at 150 Hz.
