New LS1 Owners - Newbie Tech - Request Part Numbers
Check the list first!!
LT1/LT4 and LS1/LS6 F-Body Parts :
http://www.ls1tech.com/forums/showthread.php?t=336981
1FST99Z
07-19-2005, 04:17 PM
what about the plastic inner fenders, and the plastic piece that bolts on to the front bumper??? acts as an air deflector for air in the radiator and into the air box from underneith
thanks
Wesley
thanks
Wesley
Hmm. I've got 'front fascia deflector' part numbers, for which there's separate left-hand and right-hand ones.
Firebird
93-97 RH = 10246272
93-97 LH = 10246273
98-02 RH = 10297290
98-02 LH = 10297291
Not sure about the 'plastic inner fenders' -- are you talking about the wheel-well liners, or the actual fender body panel? :)
i hate to ask,
but work 6 days a week, so hard getting to a chevy dealer
need # for rear tail pipe hangers, mine are shot.
any help... much appreciated !
Abe99
08-11-2005, 01:29 PM
Need part # for steering gear on a 2000 trans am. I saw the part number on the sticky but thats for a earlier model. Thanks
i hate to ask,
Is this what you're looking for? :)
Exhaust Muffler Hanger (98-02) = 10407350
steering gear kit (Delco rack and pinion - remanufactured) (98-02) = 26062311
It appears to be the same number for all the years :)
hope so bro... look it up now,
but really, really thanks
prince xizor
08-13-2005, 10:23 PM
What are the part numbers for the little rubber gas door stoppers, and the little push in clip/pin for the back bumper to keep the bumper from rattling.
Fuel Tank Filler Door Bumper (on door) (need 1 of these) (93-02) = 10172357
Fuel Tank Filler Door Bumper (on pocket) (need 2 of these) (93-02) = 10257216
Rear Bumper Fascia Retainer (push-in) (22.5mm long) (need 6 of these) (93-02) = 5973400
1FST99Z
08-16-2005, 07:35 AM
Firebird
93-97 RH = 10246272
93-97 LH = 10246273
98-02 RH = 10297290
98-02 LH = 10297291
the wheel well liners.
thanks
Wesley
What about the grey center console. I really just need the part where the shifter boot connects to the center console. That whole front piece. Thanks (I saw ebony camaro, I didn't know if it would be the same, prolly not since it's a different color) I don't know if they changed grey's but obviously mine is a 98. Thanks.
thanks
Wesley
Front Wheel Well Liner (98-02 Firebird), RH = 10296523
Front Wheel Well Liner (98-02 Firebird), LH = 10296524
Front Wheel Well Liner (98-02 Camaro), RH = 10296525
Front Wheel Well Liner (98-02 Camaro), LH = 10296526
Are you referring to the "center console compartment lid" that I had listed? :) (That's one that I hadn't looked up myself before, and now that I checked on it myself, I'll be revising that listing - it's not color-specific, that's the only one they offer; it's the same on both Camaros and Firebirds; and there's different ones for 98-99 and 00-02 for some reason.)
center console compartment lid (98-99) = 10273748
center console compartment lid (00-02) = 10421355
That doesn't seem to look like "the part where the shifter boot connects to the center console", though... that would probably be this:
Firebird center console trans. shifter opening trim (98-99) (M6 trans - RPO MN6) = 10297905
Firebird center console trans. shifter opening trim (98-99) (M5 trans - RPO M49) = 10297906
Firebird center console trans. shifter opening trim (98-99) (A4 trans - RPO M30) = 10297909
Firebird center console trans. shifter opening trim (00-02) (M6 trans - RPO MM6) = 10413130
Firebird center console trans. shifter opening trim (00-02) (M5 trans - RPO MM5) = 10413132
Firebird center console trans. shifter opening trim (00-02) (A4 trans - RPO M30) = 10413138
Here ya go this is what I'm talking about.
Cool, then looks like the "shifter opening trim" is the correct part :)
It includes the area where the cigarrette lighter is, and the area where the ashtray next to the shifter is, etc.
SporkLover
08-25-2005, 10:56 AM
Does the SS Third light assembly include the red reflector?
12369969
Thats all I really need... somebody over torqued it before I got the car.
yodawagon
08-25-2005, 11:32 AM
whats the part number for the fuel rails with the factory return line.
12369969
Can't tell for sure from the diagram, but I don't see it listed separately, so I'd guess it's included. :)
LS1 fuel rails (AC-Delco #217-1401) = 12562815
CaMaRoZ28LS12000
09-09-2005, 10:47 AM
Do you have the part number for the rear window defrost switch?
'Rear Window Defog Switch Pushbutton' unfortunately looks like it's not sold separately, only available as part of the whole HVAC control assembly. The Rear Window Defog Relay is also listed as only being available with the whole control assembly.
CaMaRoZ28LS12000
09-10-2005, 12:48 PM
Ok thanks
white99
09-11-2005, 12:51 PM
I am looking for the left A.I.R. valve. gm part number is 12559188 or A/C delco part number 219244.
I am pretty sure that is the part number. It is for a 1999 trans am M6 - LS1.
That is the 1999 left A.I.R. pipe, which comes with the valve, but if all you need is the valve, here's what you want :)
LS1 Secondary Air Injection (A.I.R.) Check Valve (98-99) (AC-Delco #214-419) = 22048212
(Both sides have the same valves.)
98V6camaro
09-12-2005, 12:01 AM
I think this thread should be a sticky. I mean this thread could be very helpful. Thats just my 0.02. Good job btw ACW.
I've got the parts numbers list stickied in the General Maintenance & Repairs forum, and it has a link to this thread. :) It used to be in the New LS1 Owners forum, but I moved it because there was getting to be too many stickies here. :lol: This thread also links back to the parts numbers list, so I left it here (at least for now) to cover this forum even though it's not stickied.
01 Red WS6
10-09-2005, 11:30 PM
I need to see if I can get a part number for the covers for the fuse/relay boxes under the hood. The stickers on mine faded and now I don't know what each fuse is for. For some reason I don't think they will be available but it's worth a shot.
ptrss22
10-10-2005, 11:27 AM
i need the part number for a 99 trans am a4 pcm? does anyone have that part number?
JayBirdWs6
10-11-2005, 11:10 AM
I'm looking for a part number for a Black Transmission plate thats bolts to the oil pan but covers up the over lap of the t56 transmission so dirt and rocks etc dont scratch the flywheel bellhousing area. Not usually a major problem, but if you get a bunch of water or junk up there I assume it could probably scar up the flywheel/pressure plate.
3800RS
10-11-2005, 01:02 PM
i need the clips to hold on the side skirt on my 97 camaro rs. can you get me the number ? thanx
99 LS1 powertrain control module = 9354896
has to be programmed prior to install
The covers are listed, but there's one part number for two different boxes, labelled as being "multi-use", so I don't think it comes with the sticker. Unless it comes with both and you choose the one you want to stick on it... but there's nothing to indicate that, so I have no idea if it does come with stickers or not.
You could just use these pages from the owner's manual that have the diagrams :) http://www.ls1tech.com/forums/showpost.php?p=2292189&postcount=2
attachments for the 'rocker panel molding kit' for 96-97 Camaro RS:
rocker panel molding retainer (8 per door): 12531209
rocker panel molding bolt (7 per door): 25543139
Is this a stock GM part that you're asking about, and what car is it from?
01 Red WS6
10-14-2005, 01:40 PM
Cool thanks for the help. I had a a part number and it came back the same for both two... I thought I had the wrong number. I found out that they list for $5.
3800RS
10-18-2005, 01:56 PM
thanx
NaughtyGirlTA
10-26-2005, 08:44 PM
I need the part number for F-Body A4 Flexplate Bolts please. (the bolts that attach the flexplate to the crank)
And also the part number for the Bellhousing bolts. (the one's that attach the A4 trans to the engine block)
Thanks! :)
Thanks! :)
Think it's these, but I'm not sure since they aren't well-labeled... should there be 3 flexplate bolts and 4 bellhousing-to-block bolts? If so, here they are:
A4 bolt (bellhousing?) (hfh, m10x1.5x40, 26 thd, 10.9 por) (4 of these) (98-02 LS1) = 14050422
A4 bolt (flexplate?) (m10x1.5x23-g) (3 of these) (98-00 LS1) = 12560397
A4 bolt (flexplate?) (m10x1.5x22) (3 of these) (01-02 LS1) = 11519291
NaughtyGirlTA
10-26-2005, 10:20 PM
Wow! You're fast!!!
Thanks!!
Beast
10-26-2005, 10:30 PM
Doesn't ARP offer those bolts? Anyone know if ARP offers intake and exhaust bolts for the LS1?
TransAmGT
10-26-2005, 11:30 PM
I need the part number for the Skip Shift Solenoid....i saw the one for the seal but i need the actual solenoid!
M6 skip shift solenoid (94-02) = 12523292
Yep, they do. http://www.sdpc2000.com/cart.asp?action=manufacturers&manufac_id=18
NaughtyGirlTA
11-02-2005, 03:31 PM
How about 3 more part numbers:
6.0 Truck Exhaust Manifold Gaskets (go against the heads)? Also, are they sold individual or in pairs?
And 6.0 Truck Exhaust Manifold Collector gaskets?
1998 F-Body LS1 Temperature Sensor (mounts in DS head, 3 pin style)?
Thanks again!!!!! :)
I need the part number for the little round thing on a firebird that covers the joint on the passenger cup holder. Sorry if you dont know what I'm talking about ....
TheSilverOne
11-02-2005, 11:18 PM
part number for an A4 shifter handle for a 02 camaro
Looks like the 6.0L uses the same ones as the 5.3L and 4.8L. Think they're sold individually.
exhaust manifold gasket = 12558573
These seem to be the gaskets between the manifolds and the cats, but I haven't found the number for these on the 6.0L (and so don't know if these are also the same or not).
Here they are on the 5.3L (might be old numbers, don't know what the new ones are if so, but a dealership should be able to cross-reference):
LS1 catalytic converter gasket (between cat and manifold) (98-02), LH = 12555806
LS1 catalytic converter gasket (between cat and manifold) (98-02), RH = 88891747
That one, I just confirmed yesterday :joecool:
LS1 coolant temperature sensor (98) (3-wire sensor: 2 for PCM, 1 for gauge) = 12551708
front cup holder trim cover (round) (97-99 Firebird, 97 Camaro) = 10288510
front cup holder trim cover (round) (00-02 Firebird) = 10421365
front cup holder trim cover (round) (98-02 Camaro) = 10281310
front cup holder trim cover (push-in for 12mm square hole) (00-02 Camaro) = 17988488
:thumb:
A4 control lever (shifter) knob (93-99 Camaro with RPO NP5) = 10079809
A4 control lever (shifter) knob (00-02 Camaro with RPO NP5) = 12563173
A4 control lever (shifter) knob (93-99 Camaro with RPO NK3) = 10111639
A4 control lever (shifter) knob (00 Camaro with RPO NK3) = 10163833
A4 control lever (shifter) knob (01-02 Camaro with RPO NK3) = 22680651
A4 control lever (shifter) handle (95-99 Firebird with RPO N36) = 12551597
A4 control lever (shifter) handle (00-02 Firebird with RPO N36) = 12563171
A4 control lever (shifter) handle (95-02 Firebird with RPO NP5) = 12563172
NK3 = Steering Wheel, Sport, Soft Rim, Simulated Leather
NP5 = Steering Wheel, Leather Wrapped
N36 = Steering Wheel, 4 Spokes, Sport
2000blackta
11-03-2005, 06:06 PM
How about gaskets for both the right and left valve covers? I couldn't find the part number for a new oil filler neck and cap either?
LS1 valve cover gasket (98) = 12556429
LS1 valve cover gasket (99-02) = 12560696
both LH and RH use the same one
LS1 oil filler tube (with o-ring seal) = 12559505
LS1 standard oil filler cap = 24504599
LS1 oil filler cap with Mobil 1 logo = 12555685
mc01ta
11-23-2005, 10:21 AM
Need an ebony driver side interior door panel part # for a 2001 trans am. Mine is cracked. Can you PM me this info too please?
WhiteRhino
11-23-2005, 11:43 AM
Do you know if there is a new part number for a T/A rear bumper cover?The one that is listed (Trans Am rear bumper fascia (cover) (93-02) = 10201178) doesnt come up as a valid part number.I've tried to find a new number and cannot locate one.
Thanks
Rear bumper try 12335526 & 12335511. Make certain prior to ordering.
WhiteRhino
11-23-2005, 12:41 PM
Thats whats messing me up.Gm parts direct has a group of numbers.
Under T/A Under Formula
10242397 10242406
10201178 12335526
12335511 12335524
10418941
So I guess I should quit being lazy and call the dealership to get the right number.Although I'm sure those are front and rear numbers mixed.I wish Gm parts direct had more info for the numbers without having to click on all of them.Even then sometimes the description isn't clear.
There's several possibilities for the interior door panel. Cloth or leather? Which entertainment package RPO (affects speaker placement) do you have -- W53, W54, W55, X10, or X20?
Do you know if there is a new part number for a T/A rear bumper cover? ... So I guess I should quit being lazy and call the dealership to get the right number.
Just call a dealership and ask what the updated part number is for 10201178 :) Let us know what you find out.
GMPD's catalog has a number of issues ;)
racer7088
12-09-2005, 06:42 PM
LT1 oil galley internal 12mm ball bearing GM plug?
Can you find the number for this? No one else seems to be able to? I had it but we lost it. Its the internal oil galley plug that diverts oil to the oil filter and is a 12mm stanless steel ball bearing from GM. Thanks very much ahead of time!
This is a difficult one... looked through my stuff for a while without finding it, then after quite a bit of searching online, found that apparently the bearing for the last main cap diverts oil to the oil filter.
10120993 is listed as being the LT1 (93-97) #5 main bearing; hopefully that's what you're looking for...?
racer7088
12-11-2005, 05:59 AM
Well it is a ball bearing that goes underneath the number 5 main cap. I will have to see or just get it at the dealer and see what it is?
Cephiros
12-12-2005, 07:51 PM
i dont know what this guy has, but i need the same part, leather, W54 RPO, 2000 year if it matters
2000 (also 2001) Firebird/TA
body style F87 (Coupe)
black/ebony leather (RPO 192 or 193)
RPO W54 (also W55) entertainment package
front side door interior trim panel, RH (passenger) = 12458755
front side door interior trim panel, LH (driver) = 12458756
BackinBlack02SS
12-13-2005, 02:17 PM
2002 LS1 Camaro valve cover gaskets.
DrEvyl
12-17-2005, 12:22 AM
It was just in a thread in here the other day, but I can't find it now, and I've looked up and down and sideways through the forum..
I need the part number for the nose insert for a Firebird... the insert with the "bird" on it that covers where the license plate goes.
I also need for a '98 Trans Am:
Emergency Brake handle ('98 pewter leather)
Driver's seat cover ('98 pewter leather, standard non-articulating seats)
Driver's seat cushion
'98 WS6 exhaust (one on the left style)
Firebird front license plate cover with bird (comes flat black, paint to match) = 10276353 :thumb:
Parking brake handle doesn't seem to be available to match the upholstery:
Firebird parking brake lever handle (grip portion) (97-99 NP5) = 10291075
Pewter isn't a leather color name... do you mean 'neutral'/taupe? :)
Firebird driver seat cushion cover, neutral (98-02) = 16813656
Firebird driver seat cushion pad (97-02 AQ9) = 16794382
LS1 WS6 exhaust muffler with tail pipe (single) (98 WS6), with polished tip = 10436321
LS1 WS6 exhaust muffler with tail pipe (single) (98 WS6), with non-polished tip = 10409537
DrEvyl
12-17-2005, 07:38 AM
Thanks, man :)
To answer your questions...
If I'm not mistaken, I think they only came in 1 color.
The window sticker for the car lists the interior color as "dark pewter", I've also seen it referred to as "graphite".
This color:
http://pics.evyl.org/PurpleTA/BPM_98-WS6_16.jpg
LT1 fuel rail crossover tube with orings and brackets
Thanks
Jason
DrEvyl
12-17-2005, 10:39 AM
Oh, BTW... my seats are AR9 seats, not AQ9. Do you have those part numbers too?
P.S. Holy crap, that catback assembly is $370! :bang:
Good :)
This color:
Yeah, they can't seem to stay with consistent terms for those interior colors! :lol:
Yep!
Looks like the closest choice listed for 98-99 is 'light gray' leather (143, AR9) driver seat cushion cover = 16813656
Don't know which of these is what you'd need, though:
driver seat cushion pad (98-02 AR9):
with wire = 16729508
without wire = 17908778
Many of the OEM parts aren't cheap :|
94-97 LT1
fuel crossover tube: included in kit 9
crossover tube retainer: included in kit 9
o-ring seals for tube: included in kit 8
service kit 8: fuel rail seal kit (AC-Delco #217-449) = 17113086
service kit 9: fuel rail crossover tube kit = 17113092
It looks like the part number might have changed for the crossover tube kit; a dealership should be able to use the old number to look up what it's changed to.
Abe99
12-28-2005, 10:55 AM
I need the part number for the flywheel bolts and the pressure plate bolts for a 2000 TA with T56.
Thanks
Abe
Thanks
Abe
M6 flywheel bolts (hfh, m11x1.5x23.5, 21 thd, 22 o.d., with sealant) (98-02 LS1) = 12553332
M6 clutch pressure plate bolts (hfh, m10x1.5x25, hdr pt, 17.3 flange) (98-02 LS1) = 12561465
BackinBlack02SS
01-05-2006, 09:05 PM
Upper passenger side ebony leather seat cover for a 2002 Camaro SS
Upper passenger side ebony leather seat cover for a 2002 Camaro SSPart#16837696
Mike
BackinBlack02SS
01-05-2006, 11:05 PM
Part#16837696
Mike
If that is the correct part number, then what is 16837707?
That would be the head rest cover on a TA seat.
Part#16837696
Mike knows what he's talking about, but to confirm since you're unsure, 16837696 is for an Ebony Passenger Seat Back Cushion Cover (00-02 Camaro), for black leather RPO 192 or 193, and seat reclining RPO AR9. :)
Mike knows what he's talking about, but to confirm since you're unsure, 16837696 is for an Ebony Passenger Seat Back Cushion Cover (00-02 Camaro), for black leather RPO 192 or 193, and seat reclining RPO AR9. :)Thanks ACW!!! Just for reference part#16837696 is for both driver & passengerside... Also RPO code 193 is for the 35th style seat pattern, 192 is for all ebony, just so there's no confussion.:cheers:
Mike
Mike
Yeah, I noticed it's the same for both seats when I was double-checking stuff before adding it to my list, but didn't change my post here accordingly.
Is the listing of the same part number for both 192 and 193 incorrect? I'm not sure exactly what may have been different for 35th seats vs 'normal' seats.
Is the listing of the same part number for both 192 and 193 incorrect? I'm not sure exactly what may have been different for 35th seats vs 'normal' seats.Yes they're are different... The 35th style seats(193) are ebony with a grey center & have the 35th SS logo embroidered at the top of the seat(part#88899145) .. Here's a pic at the bottom of them... 192 is for ebony only.:)
http://img175.imageshack.us/img175/948/64374419full9tw.th.jpg (http://img175.imageshack.us/my.php?image=64374419full9tw.jpg)
http://img175.imageshack.us/img175/8845/58117363full2lw.th.jpg (http://img175.imageshack.us/my.php?image=58117363full2lw.jpg)
Thanks, that's what I was suspecting. I had 35th seat cover numbers, but apparently GM forgot about them when writing those pages! :) Doh.
Silverbird01
01-07-2006, 12:06 AM
Need part numbers for the left and right interior door panels on a '01 TransAm WS6. Interior color is ebony(dark gray) leather and the car has the 10 speaker Monsoon stereo system. Can you help me? Mine has the dreaded cracks on the upper part of the sill.
Thanks!
Thanks!
This should be it :)
00-02 Firebird
F87 body (coupe, not convertible)
Ebony leather (RPO 192)
10-speaker Monsoon stereo (RPO W55 - CD, or RPO W54 - cassette)
front side door panel interior trim
RH = 12458755
LH = 12458756
Silverbird01
01-08-2006, 02:08 AM
00-02 Firebird
RH = 12458755
LH = 12458756
Thanks alot! I knew they wouldn't be cheap ..........554.00 ea.:eek2:
Oh well, gotta have them!
I'm curious, are you a GM parts guy? You seem have real good access to the part numbers.
CRAGER
01-08-2006, 06:52 AM
Do a search. There is a site where you can download the parts catalog that has every part number for our cars. :thumb:
Peace,
Craig.
Silverbird01
01-08-2006, 08:56 AM
Peace,
Craig.
Thanks for the suggestion but that is not the reason why I'm asking.
What is the reason then, hoping for a discount or something? ;)
I think MM98 might work for a dealership.
We do have a sponsor who sells GM parts: http://www.sdpc2000.com/cart.asp?action=catalog_start&catid=873
Silverbird01
01-09-2006, 07:29 AM
Naa, you all are way off base:)
I have a non F body question I need to find out about. I just wanted to ask a good GM technician or parts counterperson/manager about a problem I can't seem to solve. I can't get any answer with the dealerships around here.
Actually its about a Grand Prix. Thats all.
Ah! Doh :) Well, I'm no professional, but I do have a bunch of GM service information (including Grand Prix), so if you'd like to start a thread in the General Maintenance & Repairs forum, I can take a look. (There's a lot of other people who also read that forum who might figure it out if I don't, too ;) )
'Trust'
01-11-2006, 11:27 PM
I cant get the part numbers to pull up on gmpartsdirect.com for the RH and LH 99-00 valve cover, is the number still correct?
Well, it wouldn't be the first time some have changed! :)
If you call a dealership, I think they should be able to cross-reference the old numbers and look up what they've changed to. Or maybe MM98 will return and look these up.
Old numbers were LH: 12559894, RH: 12561819.
Please let me know if you find out what they've changed to.
'Trust'
01-11-2006, 11:46 PM
I'll call em in the morning and let you know, thanks!
EDIT: Found one, the RH was changed to 12582224 (which matches the 02 valvecover), and the left is still showing up as unlisted.
'Trust'
01-12-2006, 03:31 PM
Alright, LH side is 12570427 and the RH is same as above, 12582224
Thanks! :) I already had those as new numbers for the 01-02 LS1/LS6 version, so I guess they decided nobody should be buying the older LS1 version anymore if they can switch to these instead.
chaman
01-22-2006, 06:26 PM
Looking for the part number for the small plastic screws that hold the trim piece over the spare tire. These are the ones you can twist open with coin. I'm looking for the ones for a 1999 TA, graphite/dark gray color.
Thanks in advance!
DrewSG
01-24-2006, 01:22 AM
Anyone know the part number for the gas cap? I lost mine and the two posted in thread don't work at GMPD.
Thanks in advance!
Think this is it :)
rear compartment trim retainer (fits 0.250 hole, 1.01 lg, 0.7 od, nylon, black) (93-02) = 10121502
I have current numbers for 93-97 and 98, but those don't help you... For 99-02, I have previous GM numbers and current AC-Delco numbers, but haven't been able to find the GM numbers that go with them. Try calling a dealership and they should be able to cross-reference these to what the number have changed again to. Post it up if you find out anything.
gas cap ('fuel tank filler cap') (93-97) (AC-Delco #GT174) = 10164142
gas cap (with tether) (98) (AC-Delco #GT222) = 22616291
gas cap (with long tether) (99-02) = 22616287 (discontinued for short version)
gas cap (with short tether) (99-02) (A-D #GT261) = ? (form. 22660003, 22616286)
gas cap (without tether) (99-02) (AC-Delco #12F58) = ?
locking gas cap (99-02) (A-D #GT270 or 12F31L) = ? (formerly 22660006, 22616294)
Super Speed
01-24-2006, 06:50 AM
Gimme the part numbers for the Passenger side manifold AIR gasket and the drivers side seatbelt plastic D looking thing that goes on the side of the seat that hold the seatbelt at a lower place, thanks!
Left out what car! ;) I had to look through a bunch of your posts to find out it's a 2000 Camaro SS.
LS1 Secondary Air Injection (AIR) pipe gasket (98-02) = 12553617
(It's the same for both sides.)
What color is your interior? Left that out too ;) Should be one of these:
front seat shoulder belt guide (96-02 coupe), neutral, LH = 16789715
front seat shoulder belt guide (97-02 coupe), pewter, LH = 16799275
front seat shoulder belt guide (00-02 coupe), ebony, LH = 16817201
byrontaylor
01-25-2006, 08:23 AM
ACW, when you get a chance there are a few PN's I need to know for a friend...first the covers for a 35th ann. camaro for the rear seats. You had the front but not the back, second, 35th silver stripes, and last, the chrome ss wheels or wheel and tire sets for myself.
BackinBlack02SS
01-25-2006, 12:12 PM
By chrome SS wheels do you mean 10 spokes or ZR1 style? Both were made only by SLP, not GM. The chrome 10 spokes have been discontinued, but I believe you can still purchase the chrome ZR1 wheels from SLP.
Camaro rear seat cushion cover (35th Anniv SS - ebony w. gray center, RPO 193) = 88899199
Camaro rear seat back cover (35th Anniv SS - ebony with gray center, RPO 193) = 88899188
35th Anniversary stripes:
10307873 - Front Fascia Stripes
10307874 - Front Fascia Lower Stripes
10307867 - LH Hood Stripe
10307866 - RH Hood Stripe
10310679 - LH Decklid Center Stripe (Convertible)
10310678 - RH Decklid Center Stripe (Convertible)
10307875 - LH Decklid Center Stripe (Coupe)
10307876 - RH Decklid Center Stripe (Coupe)
10307877 - LH Spoiler Stripe
10307878 - RH Spoiler Stripe
I've never seen GM part numbers for them, whether they're still available or not. I also haven't seen GM part numbers for any tires.
Here's SLP and a couple other sponsors that sell the chrome Camaro SS SLP ZR1 wheels:
http://www.slponline.com/view_product.asp?P=80041
http://www.lmperformance.com/746/1.html
http://www.afterthoughtsauto.com/chrome-ss-wheels.html
The non-chrome ("Machine Polished Face") 10-spoke SS wheels (35th Anniversary) are available and have part numbers, but that's not what you wanted.
byrontaylor
01-26-2006, 09:34 AM
Thanks alot ACW, the GMPD is changing PN's I guess and their's wouldn't work on about half the stuff. If I find anything has changed I'll let you know.
thanks again
Byron
SSideExhLS1
01-29-2006, 11:53 PM
i have a part number that i cant seem to find anywhere, the GM# is 16523943 it is a bracket where the two headlamps mount on a 2001 Trans Am. if this is no longer available, then whats the part number to the entire headlamp assemblies for this vehicle, both right and left???
thank you very much!!!!!
Where did you come up with that number from in the first place? :confused: Seems to be an incorrect number.
Firebird headlamp housing panel upper bracket (98-02) = 10247777
Or this?
Firebird headlamp support (98-02), RH = 10414795
Firebird headlamp support (98-02), LH = 10414796
99whitews6
01-30-2006, 04:54 AM
Part number for crankshaft key for a 99 Trans Am Ws6? The key that slides into the crank keyway to hold the timing sprocket in place.
Also, part number for bellhousing dowel pins that align the bellhousing to the tranny.
Thanks
02WS6Bird
01-30-2006, 08:52 AM
How about the Bolts to the Oil Pan. I somehow managed to break one of the 2 in the back (the very long bolts) if you could please let me know
SSideExhLS1
01-30-2006, 10:52 AM
Or this?
it is the bracket where you actually screw on both headlights, its whats right behind the plastic bezel. and its in front of the bracket that mounts to the upper radiator support. if it helps, this bracket contains one small spring for each headlamp, i guess they are to adjust the headlamps. i got the part number from the actual piece. thanks for your help!!!!
ThanksCrank key- part#12561513
Dowel pins- part#1453658
How about the Bolts to the Oil Pan. I somehow managed to break one of the 2 in the back (the very long bolts) if you could please let me knowRear pan bolts- part#12554990
thank you very much!!!!!Yeah that part is not serviced through GM... It's part of the headlight assm...
LH Assm- part#12336001
RH Assm- part#12336000
99whitews6
01-30-2006, 07:48 PM
LS2 lifter tray part number?
LS2 lifter tray part number?Part#12595365
Ωmega
02-01-2006, 07:32 AM
Does anyone know the part number for the clips that hold the tranny cooler hard lines in the trans?
BLUE99T/A
02-01-2006, 08:32 AM
I can't seem to find a # for the knock sensor wiring harness. Damn plastic end broke off. thanks. 99 fbod
TRANSAM75
02-01-2006, 08:40 AM
Knock Sensor Harness #12597415
BackinBlack02SS
02-01-2006, 01:06 PM
EDIT: Anyone know the gm part number for the red vaccum cap pictured here? http://www.ls1howto.com/howto/genii...gerside_pcv.jpg They came with the LS6 valley cover, and I believe the C5 Z06 from the factory.
Does anyone know the part number for the clips that hold the tranny cooler hard lines in the trans?Part#24205103
EDIT: Anyone know the gm part number for the red vaccum cap pictured here? http://www.ls1howto.com/howto/genii...gerside_pcv.jpg They came with the LS6 valley cover, and I believe the C5 Z06 from the factory.Sorry, but it's not a servicable part from GM.. Any aftermarket parts store will have multiple sizes of those though.
Holeshotz
02-01-2006, 09:34 PM
I need a # for the oil pan bolts. In particular the long 10 mm bolts at the rear of the oil pan that thread into the rear cover.
TIA
2002z28
02-02-2006, 09:04 AM
could someone pm me the part number for the interior piece(the opening is about 2"x4") right in front of the shifter(m6)? my interior is ebony and model year is 2002.
also, who about the plastic fastners that hold the interior piece that covers the spare tire?
thanks in advance.
justin
For future reference, often a number on a part is just the casting number, which doesn't match up with the part number needed to order it (if there even is one). :)
Here is the working link: http://www.ls1howto.com/howto/geniii/ls6pcv/passengerside_pcv.jpg
http://www.ls1howto.com/index.php?article=18 says the size you need:
[one] 5/16" vacuum cap, if your LS6 cover doesn't come with a red one pre-installed
If for some odd reason your LS6 cover didn't come with one, any autoparts store will have one for a buck or two. You should need a 5/16" cap.
Super Speed
02-02-2006, 07:09 PM
Thanks a bunch man :hail:
oh hbout the passenger side air bolt? Thanks!
Mike00ss
02-03-2006, 02:03 PM
On the center consol in a 2000 camaro. The door for the ash tray, that opens and closes. What’s the part number for just the door.
Thanks.
TRANSAM75
02-03-2006, 02:29 PM
That Door Is Part Of The Top Console Plate,i Would Need More Info To Get A Part # And Price.
Thanks.
ashtray lid/cover, manual trans (97-02) = 10271366
ashtray lid/cover, auto trans (97-02) = 10408634
Sounds like the ashtray..? Not sure if you want the compartment piece or the cover for it, though.
ashtray, manual trans (00-02) = 10261420
No choice on color, so might not exactly match.
thanks in advance.
justin
I think I looked that up before and it was this:
rear compartment trim retainer (fits 0.25 hole, 1.01 lg, nylon, black) (93-02) = 10121502
Same for both sides:
LS1 Secondary Air Injection (AIR) pipe bolt (98-02) (m8x1.25x24.4, 20 thd) = 12556127
Mike00ss
02-04-2006, 10:18 PM
8banger
02-07-2006, 09:51 PM
I NEED these part numbers:
-The part number for one of the four bolts that connects the wheel hub, to the steering knuckle/spindle. I need to order one, but I don't know the part number.
-The metal retainer clips that hold the transmission cooler lines into the transmission. I lost one of mine, and once again do not have the number.
Please help. Thank you.
Adam
front wheel hub bolt (93-02) (4 on each wheel) (m10x1.5x50, 10.9 por) = 11508355
Adam
A4 retainer clips for transmission cooler hard lines (98-02) = 24205103
8banger
02-09-2006, 01:24 AM
Amazing. Thank you.
2002z28
02-09-2006, 09:13 AM
ACW,
thanks im halfway there knowing the fastner part number. im looking for the interior piece that is located in front of the shifter(towards the engine). it is underneath the hvac controls. i put a hole in mine for a air/fuel gage that im going to relocate.
thanks in advance.
ACW,
thanks in advance.
The one next to the lighter? :)
If so, that's one of those tricky ones with incomplete listings and a number of different variations, but I think I finally have them figured out:
switch plate (by lighter), 1 opening (for TCS) (no logo) = 10280509
switch plate (by lighter), 1 opening (for TCS) (Pontiac) = 10411289
switch plate (by lighter), 1 opening (for convertible top) (no logo) = 10280510
switch plate (by lighter), 1 opening (for convertible top) (Pontiac) = 10411284
switch plate (by lighter), 2 openings (for TCS and convertible top) (no logo) = 10280511
switch plate (by lighter), 2 openings (for TCS and convertible top) (Pontiac) = 10411285
4bangermustang
02-11-2006, 06:58 PM
coil pack bracket 99 style..
ilovefirstgens
02-11-2006, 09:16 PM
Cam position sensor, water pump bolts, alternator bracket to engine bolts, and if there is some sort of bolt in bracket to hold the pcm, thanks!
LS1 coil bracket (99-00) = 12562864
LS1 coil bracket (01-02) = 12563288
Looks like the 99-00 one might not be available anymore and you'd have to change to the 01-02 one.
LS1 camshaft position sensor (with seal) (98) (AC-Delco #213-355) = 12560229
LS1 camshaft position sensor (with seal) (99-02) (AC-Delco #213-363) = 12561311
LS1 camshaft pstn. sensor connector (3-way black F) (98-02) (AC-Delco #PT117) = 12085495
water pump bolts,
water pump bolt (98-02) (m8x1.25x82.6, 31.8 thd, 17 od, GM7114M mzf) (need 6) = 12551926
Looks like all five of these bolts go through the bracket to the engine:
LS1 alternator rear bracket bolt (98-02) (hfh, m10x1.5x35, 32 thd, 22.3 od) (1) = 11515767
LS1 alternator rear bracket bolt (98-02) (hfh, m8x1.25x50, 27 thd, 17.6 od) (1) = 11509666
LS1 alternator to bracket bolt (98-02) (hfh, m10x1.5x125, 25 thd, 22.3 od) (2) = 11516366
LS1 alternator front bracket bolt (98-02) (hfh, m10x1.5x90, 22.3od, dim A30) (1) = 11516360
LS1 PCM bracket (98) = 10284308
LS1 PCM bracket (99-02) = 10275815
LS1 PCM bracket bolt (98-02) (hfw, m8x1x25, 17 od, 6202M stl) = 11516413
joshua32
02-12-2006, 10:30 PM
ACW,
I am looking for a part number for a right hand side bracket. It is the bracket that the bumper support (the plastic one that goes at the top of the bumper) attaches to on a 98-02 trans am. The part number I have for the left hand side is 10280338 LH. I searched gmpartsdirect and also buy-oem-parts.com but have had no luck at all. Any help would be greatly appreciated.
Thanks,
Joshua
ACW,
Thanks,
Joshua
Hm, where did you get that 10280338 number? I'm not seeing it anywhere.
Andros
02-13-2006, 10:50 PM
Need part # for 2002 transam k- member, I need a new one fast, mine is bent. I can either get it from gm parts direct or from a friend of a friend.
LS1 front crossmember (k-member) (98-02 coupe) = 10293578
LS1 front crossmember (k-member) (98-02 convertible) = 10438427
Those are the original numbers, but looks like they may have changed... I don't know what the new ones are, but a GM parts dealer should be able to cross-reference them. Let us know if you find out the new number for one of those :)
txhorns281
02-14-2006, 05:57 PM
Ok, when i try the part number for a water pump at GMPartsdirect, it cannot locate anything for it. Same thing for rear main cover (not seal). Looking for the right part #s for these two! Thanks!
Waterpump- #89017593
Rear cover- #12572014
Mike
fasteddyss
02-15-2006, 07:47 AM
I need the part #'s for the following for a 99 camaro:
Rear hatch struts
Latch for hatch, on body
Outside rear view mirrors
I have a parts manual in pdf and have tried looking these up. I end up with multiple part #'s and not good #'s.
Thanks!!!
Rear hatch struts
Thanks!!!
Rear latch- part#16635227
LH deck lid strut- part#10419989
RH deck lid strut- part#10419988
LH side mirror assm- part#10279358
RH side mirror assm- part#10279357
Mike
fasteddyss
02-15-2006, 08:19 PM
Mike
Thank you.
Please help me understand this though, why do I get different part #'s from GMpartsdirect??
They give me 10193275 for both deck lid struts and 16629978 for the latch.
The mirrors are the same #'s
I really just want to understand these different #'s, Maybe they all supercede to the same??
Thanks!!!!! :)
Thank you.
Thanks!!!!! :)No problem... The reason those #'s are different, is because they are for a convertable... The #'s I gave you are for a t-top/hard-top.:)
Mike
fasteddyss
02-16-2006, 12:43 PM
Mike
Thanks, I guess I know now not to trust GM parts direct for the right #'s. They never asked if I had a coupe or convertible.
BackinBlack02SS
02-16-2006, 12:47 PM
Did you give them your VIN #? They already knew.
fasteddyss
02-16-2006, 03:00 PM
No, I just used their parts locator. They just ask make and model, not anything else.
CHarris
02-27-2006, 11:56 PM
Do you have the part numbers or sizes for...
1) The bolts for the C5 corvette accessory brackets?
2) The bolts and little retainer bracket that holds the Power steering pump to the C5 bracket?
3) The Power steering pump reservoir bracket/mount for a C5?
4) The idler pulley/spacer/bolt combo for the C5 accessory package (not the tensioner that moves... just the dead pulley)?
5) The actual bolt sizes for the intake manifold?
6) The little gaskets that go with the intake colant crossover piping (front and rear)?
Thanks!
If you're referring to the 'alternator/generator and power steering pump bracket':
generator bracket polt, position 1 (hfh, m10x1.5x80, 30 thd, 22.3 od, 9.8, 7114m) (need 3) (C5 Corvette) = 11516357
generator bracket polt, position 2 (hfh, m10x1.5x70, 30 thd, 22.3 od, 9.8 mat, 7114m fin, mach, reduced body) (need 1) (C5 Corvette) = 11516356
power steering pump front brace (C5 Corvette) = 12555693
power steering pump front brace bolt (hwh, m8x1.25x40, spl fullthd, ac pt, 10.9 pzor) (need 2) (C5 Corvette) = 11515758
power steering fluid reservoir bracket (C5 Corvette) = 12555222
There's two 'idler pulley' listings, not sure which you're asking about:
belt idler pulley (C5 Corvette) = 12564401
AC compressor belt idler pulley (C5 Corvette) (AC-Delco #15-4669) = 12557334
intake manifold bolt (with flat washer) (m6x1.0x21.8, 13.6 od, gm500m, zf, mach, adhes) (need 10) (C5 Corvette) = 12552344
Thanks!
Looks like this is one is used for both front and back:
engine coolant air bl(?) pipe o-ring seal (C5 Corvette) = 12551933
Tallon535
02-28-2006, 11:10 AM
I'm looking for the part number for the WS6 radiator support. The lower airbox as it is sometimes called. The one that is elevated an inch or so for the ram air.
Also, in the listing it has fog lamp assemblies for 93-97 Trans Ams, I have a 2000. What are the part numbers for the fog lamp assembly and turn signal sockets?
Thanks in advance!
-Tyler
CHarris
03-01-2006, 02:07 AM
Thanks for your help!!!! That is awesome!
One more thing on the idler pulley pulley question...
Isn't there a third idler pulley on the Corvette system? I have the one that goes to the A/C tensioner. I also have the one on the main belt tensioner. Isn't there another one that does not serve as a tensioner? If so... that's the one I need the part number for.
Well, those were the only two that actually said 'idler' in their name. There is also a water pump pulley and a power steering pump pulley, but those are a good bit larger. Then of course there's the drive belt tensioner and the AC compressor belt tensioner. I don't see anything else in the belt system. :confused:
CHarris
03-02-2006, 10:04 AM
Hmm... thanks for all the support! I was able to buy all the remaining bolts I needed for about $35 from a bolt supply business in town. :)
Not officail GM bolts.. but bolts that would do the job!
Nice4thgenZ
03-02-2006, 04:11 PM
i need the ls6 valley cover part number
Silverbird01
03-05-2006, 04:58 PM
ACW,
Sorry this isn't F-body related but I need the part # for the 12 Disc CD changer cable (wire harness) for a 2000 Pontiac Grand Prix GTP.
I need the whole cable that goes between the dash head unit back to the disc changer.
Thanks for all the help.
Steven
LS6 valley cover = 12568002
ACW,
Steven
Don't have a lot of information on those cars, but I found it :)
CD changer wiring harness (95-03 Grand Prix) = 12344015
Silverbird01
03-06-2006, 11:23 PM
Thanks a bunch! I couldn't find anywhere, I really appreciate it.
Trojan35
03-08-2006, 12:25 PM
Trans Am Center and Side Vent Part #'s for ebony interiors?
I believe 17997681 is the part # for the center AC's. The side vents are slightly larger.
LH vent- part#17997683
RH vent- part#17997682
Part#17997681 is the correct # for the center vents.
Mike
Trojan35
03-09-2006, 03:51 PM
Mike
Awesome, Thanks.
TAvsGN
03-11-2006, 09:46 AM
I am looking for a passenger side "ground effect" (below the door on the bottom of the car) for my 98 Trans Am. The # stamped on the part is 10202211. Can't find that listed anywhere. Called a dealer and they couldn't find that # either, but I tried to explain what I wanted. He gave me the # 12369003. This part lists at over $900. I can't believe this is right. $900 for a single piece of plastic? I found the second number online, but no one has an illustration so I can be sure. Any help? My part was cracked before I bought the car by someone that didn't know how to lift an FBody!
Yep, unfortunately that is the correct item.
Firebird rocker panel molding kit (98-02), RH = 12369003
Firebird rocker panel molding kit (98-02), LH = 12369004
List price is $959, but some dealers do sell it for less than $600.
It is part 13 in this picture (also includes the associated bolts and such):
http://img207.imageshack.us/img207/3019/firebirdmoldings98025xj.th.gif (http://img207.imageshack.us/my.php?image=firebirdmoldings98025xj.gif)
Numbers stamped on parts are often the 'casting' numbers used for making them, which aren't related to the part numbers used for selling them.
TAvsGN
03-13-2006, 09:33 PM
I talked to a friend at a dealership today. He said that part is for a car with the W68 option on the build sheet. My T/A does not have that on the list. He put my VIN in his computer and found part #12517222 that should fit my car. It has the code Y82, which is in my build sheet. Does this sound right? I hope cuz that is a cheaper part. Thanks for your help here!
Yup that's the correct part#.... And if he's a good friend, he should be able to get that for you well under the $285 price tag!:)
Mike
87f383
03-14-2006, 10:16 AM
I need part numbers for 98 LS1 Dipstick assembly... I need the dipstick, tube, any seals and mounting hardware, etc. etc.
Thanks!
Thanks!
Dipstick- part#12551581.
Dipstick tube- part#12551577, includes new o-ring seal.
Dipstick tube mounting bolt- part#11515765(M10x1.5x25).
Mike
ilirw325
03-15-2006, 01:13 AM
Part number for the little silver sqaure GM logo that the General puts on all of its cars from 2005 and up? if possible for someone to look up
thanks
thanksPart#15223484
ilirw325
03-15-2006, 08:27 PM
thanks :cheers:
you da man
Super Speed
03-18-2006, 01:19 PM
ACW could you give me the part numbers for the screws that go to the front seat shoulder belt guide? Part number or thread size//length thanks a ton man!
F-Body front shoulder belt guide screw (m4.2x1.41x20 oval hd) (97-02 coupe), LH = 11516665
F-Body front shoulder belt guide screw (m4.2x1.41x35 oval hd) (97-02 coupe), RH = 11514957
BackinBlack02SS
03-18-2006, 07:38 PM
Is there a part number for the drivers side sail panel speaker bolts and the metal clips the bolts screw into?
rear door quarter speaker bolt (hwh, m4.2x1.41x25, 17 od) (97-02) = 11508233
rear door quarter speaker nut (u-shaped, m4.2x1.41, 17 long, 13 wide) (97-02) = 11513715
Super Speed
03-18-2006, 11:29 PM
whats lh or rh mean :confused: :jest:
For anyone who actually doesn't know, that's why I have that in the first post of http://www.ls1tech.com/forums/showthread.php?t=336981 ;)
LH (Left-hand side) = driver side
RH (Right-hand side) = passenger side
WhiteRhino
03-21-2006, 05:49 PM
Does anyone know the part numbers for the rubber inserts that go into the cup holders?I need the front and both rear.I've looked everywhere and cant find the numbers.
BackinBlack02SS
03-21-2006, 08:34 PM
Thanks for your help. I called a couple local dealers today just to double check and was told the correct part numbers are 11516715 for the bolt and 15650655 for the u-nut.
Maybe I'm overlooking something, but I'm not seeing those; they might not be sold separately. Perhaps MM98 can find them.
Um... I don't know how in the world they came up with those, but I don't think those are what you're looking for.
The 15650655 nut is used for rear license plate lamps, and is a different size. (4.2x1.4, 19.3x213.8 or something like that)
And the 11516715 bolt is used for something else (lights or AC related, wasted quite a bit of time already trying to find exactly what), and is a different size too. (M4.2X1.41X20, 12.5 od)
BackinBlack02SS
03-23-2006, 08:09 PM
I called 3 different dealerships, they used my vin # to look the part numbers up and they all said the same thing.
I called 3 different dealerships, they used my vin # to look the part numbers up and they all said the same thing.Bolt part#11516715 is the right one, however the nut they looked up for you is wrong... It's part#11513715.
Does anyone know the part numbers for the rubber inserts that go into the cup holders?I need the front and both rear.I've looked everywhere and cant find the numbers.98-02's didn't come with those that I'm aware of & I don't show any listed in my catalog either... 93-96's did have front ones though & the part# is 10248387.
Mike
Mike
Thanks for clearing that up! :)
Roadhouse
03-27-2006, 09:04 AM
What is the part number for the C5 Z06 Red plug wires?
Thanks.
87f383
03-27-2006, 03:52 PM
1998 F-body Motor Mount Nuts... I have the 2 giant bolts but misplaced the nuts . Hell.. just give me both part numbers please.
Thanks.
Part#89017270
Bolt- part#11516940
Nut- part#11515744
Mike
TEX02SS
03-30-2006, 03:16 PM
can i have the part number for the SLP dual/dual exhaust on 02 camaro ss. On the slp site, i have found 10754, but there is no picture so im not sure if that is the one i am looking for. Thanks for your help!!
BackinBlack02SS
03-30-2006, 03:51 PM
There is no GM part number for that exhaust. It was made exclusively by SLP as a second sticker Y2Y option. The SLP part number listed in my 02 SS owner's manual is 10717.
Abe99
03-31-2006, 05:05 PM
Need part # for rack pinion's boot on a 2000 TA ams ws6. Thanks
Need part # for rack pinion's boot on a 2000 TA ams ws6. ThanksPart#21011025: includes boot, clamps & grease
Mike
Mo6893
04-03-2006, 11:24 AM
I believe the PN# for the LS1 TB gasket is incorrect.
LS1 stock 48mm throttle body gasket = 10105379
I think this should be: "LS1 stock 75mm throttle body gasket = 12552542"
Whoops, yep, 10105379 is the LT1 gasket. Got it right there further up on the list.
I got some of those from things other people had posted, as a shortcut to get the ones people liked to ask about, and checked a lot but not all of them...
I suspect that was on an older list that only covered LT1s but didn't specify the items were for LT1s, then someone posted it mixed in with a bunch of LS1 stuff, and I overlooked the mixup.
Thanks for catching that! :)
Mo6893
04-04-2006, 07:39 AM
No problem.
I appreciate the list you've put together. :thumb:
MrEddie
04-04-2006, 01:25 PM
Hi, I searched the list am looking for the following:
2000 Z28 M6:
Lower radiator hose
radiator cap
thermostat
serpentine drive belt
Thanks!
2000 Z28 M6:
Lower radiator hose
radiator cap
thermostat
Thanks!
Lower rad hose: #10271555
Rad cap: #10316828
Thermostat with housing: #12571261
Serp belt: 12569527
AC belt: 12569529
Mike
Blksilvr
04-04-2006, 08:39 PM
Do you have the part number for the 8 bolts that go in the motor mount to the block?
did not see them on the list
Thx
Rik
Thx
Rik
Part#11516328(M10x1.5x30)
v8hunter
04-05-2006, 12:40 PM
What is the part # for the intake air temperature sensor on a 99 ls1 ta. It is the part that fits in the air intake lid with a 2 wire connector.
Part#12160244
MetalKnight
04-11-2006, 10:15 AM
Hi Guys,
I need a few part numbers not listed in the other thread.
Vehicle: 1999 Trans Am WS6, 30th Anniversary, w/ Monsoon Sound, manual transmission. White/Gray 30th Anniversary specific interior colors.
I can PM you my VIN if needed.
1. Power Steering Cooler (Leaking into coolant)
2. Drivers side interior door panel (Cracking)
3. Passenger side interior door panel (Also cracking)
4. Drivers side armrest (Broken fiberglass)
5. Passenger side armrest (Whadd'ya know, also broken)
Thanks a whole bunch! :hail:
LS1MONSTER
04-13-2006, 03:15 PM
manual shifter boot (comes with retainer ring) (97-02) = 10271369
Does this come in only one color? I have the grey interior or whatever its called.
That's the only one, as far as I know... good news is, it should be gray :)
Hi Guys,
power steering cooler (98-02 with RPO V12) = 10417037
Here's the only armrest versions I have... if your gray isn't graphite, you'll have to get it from MM98.
armrest (93-02), graphite, RH = 16670348
armrest (93-02), graphite, LH = 16670349
armrest (00-02), ebony, RH = 16638554
armrest (00-02), ebony, LH = 16638555
door trim panel (99, white leather - RPO 105, Monsoon sound - RPO W54/W55), RH = 12456462
door trim panel (99, white leather - RPO 105, Monsoon sound - RPO W54/W55), LH = 12456463
That's the original door panel numbers, but it looks like they've changed, don't know what to.
BackinBlack02SS
04-13-2006, 10:05 PM
Need the part numbers for the upper ball joint nut cutter pins and the lower front shock spring perches. Just for clarification, the cotter pins in this pic. Need both the drivers side and passenger side.
http://www.ls1howto.com/howto/fbody/frontsuspension/pics/IMAGE003.jpg
The black metal lower spring perch that slides over the shock and sits on the ring around the shock. Here is a pic for reference. Need both the drivers side and passenger side.
http://www.ls1howto.com/howto/fbody/frontsuspension/pics/IMAGE011.jpg
Sounds like these are what you're looking for... same for both sides:
front spring seat (93-02) = 22099275
front upper control arm cotter pin (93-02) (0.09375x1.5) = 103376
MetalKnight
04-14-2006, 12:58 AM
Thanks a lot, I apprecite the effort! :)
)V(etalKnight
LS1MONSTER
04-14-2006, 10:17 AM
THANKS ACW!!! :)
BackinBlack02SS
04-18-2006, 11:52 PM
Part number for the small plastic wire clip, or loom, that the abs wire runs through. It inserts into the front lower control arm on both the driver and passenger side. Basically looks like 2 circles with a fastner on the end if that helps.
black99z28
04-20-2006, 07:38 PM
I was wondering if you could find the part number(s) for the rear compartment trim peice that the speakers go in on both sides.
jack-hole that owned the car before me cut the holes to fix 6x9's in there.
speedfrk77
04-21-2006, 08:14 PM
I need the part #'s for all the speakers for a 99 camaro z28 Monsoon stereo.
Can you break them down in left and rights?
TEX02SS
04-23-2006, 08:44 PM
can i get the part # for the 12 disk changer for 02 monsoon stereo in camaro. Thanks!!
LSWannabe
04-23-2006, 11:36 PM
Need PN for our PS pump assembly.
Thanks.
WhiteRhino
04-24-2006, 09:01 AM
Mike
I forgot I asked. Thanks for the help. Shouldnt the pre 98 years still have the same console. I dont know if they changed them or not. I dont think they did but I cant remember what my 95 TA looked like compared to my 98 TA.
It was for the rubber cup holder inserts. I know my 97 Z28 had the rubber cup things in the single front and in the rear double holder.
Is there an LT1 stock clutch replacement kit like ones for LS1/6?
DataCom
04-24-2006, 04:59 PM
Hello,
I have a 94 formula and am having a problem with the LH upper door hinge Part #. When I ordered the parts from the dealer I ended up with a 2 hole hinge. they said their parts cataloge listed 16630875 as the upper hinge for 93-02.
According to the list below it should be 95-02 and the 3 hole should be 16626519. However nothing showed up in their cataloge using the part # 16626519.
At this point I am at a loss of where to get a new 3 hole upper hinge with the plate or the part numbers. Also when I searched/googled for 16626519 nothing showed up. The part numbers below are from this site. Is 16626519 the wrong number?
front side door lower hinge (93-02), RH = 16628998
front side door lower hinge (93-02), LH = 16631043
front side door upper hinge (93-02), RH = 16630874
front side door upper hinge (95-02), LH = 16630875
front side door upper hinge (93-94), LH = 16626519
DataCom
Hello,
DataComHere you go man:
Upper LH hinge, part#16630875 & you must also use plate #10268961
Upper RH hinge, part#16630874 & you must also use plate #10268960
Mike
Here you go man:
Mike
So the 95-02 upper LH hinge is now also being used for 93-94? :)
jlarsen
04-24-2006, 11:46 PM
Need the number for the front defroster vent cover that sits just on the A-pillar molding, the little circle one a little bigger than a quarter
So the 95-02 upper LH hinge is now also being used for 93-94? :)Correct, along with the two plates that I listed are needed for the swap on the 93-94's.:nod:
LH side: part#10268190
RH side: part#10268189
Thanks.
LT1 power steering pump kit (93-97) = 26040864
LS1 power steering pump kit (98-02) = 26068936
12-disc CD changer (97-98) = discontinued, use 99-02 (formerly 16199553)
12-disc CD changer (99-02) = 25678544
12-disc CD changer cartridge (97-02) (Pioneer #JDT-1212) = 25678545
12-disc CD changer kit (changer and cartridge) = 12371528
wiring harness for 12-disc CD changer (97-02) = 12344003
Camaro door front speakers (97-02 - UZ7 premium audio), RH = 9361859
Camaro door front speakers (97-02 - UZ7 premium audio), LH = 9361869
Camaro rear quarter trim panel speaker (97-02 - UZ7 premium audio) = 16217731 (use same for LH and RH)
Camaro rear sail panel (B-pillar) speaker (97-02 - UZ7 premium audio) = ? (formerly 16235651) (use same for LH and RH)
If there is a kit package like those, I'm not seeing it.
MM98, any idea on this?
Think I found the wiring harness you're talking about, but I'm not having much luck on that fastener. It might only come together with the wiring harness.
Camaro rear quarter interior trim panel:
(97-99 with UZ7 premium audio), neutral, RH = 16675643
(97-99 with UZ7 premium audio), neutral, LH = 16675644
(97-99 with UZ7 premium audio), gray, RH = 16633448
(97-99 with UZ7 premium audio), gray, LH = 16633453
Paul Bell
04-26-2006, 10:14 PM
1994 Firebird part numbers:
Tail/stop lamp sockets (pigtails), for the 1157 lamps.
and
The body plug in the rear floor pan.
Thanks!
MrEddie
04-27-2006, 09:02 AM
2000 Z28 M6
2 heater hoses going from engine to heater core
throttle body coolant lines
Thanks!
SleeperSS
04-27-2006, 12:15 PM
Does anyone know the part # for the hose that goes from the the radiator to the powersteering cooler. Its the inlet hose.
and
Socket: part#12141493
Floorpan plug: part#10208798
2000 Z28 M6
Thanks!
Heater core hose assm: part#10415020(includes both hoses)
TB coolant lines: part#12556452 & 12562165
Hose from cooler to radiator: part#10413567
Mike
fast377
04-30-2006, 11:04 AM
I could use a few part numbers please...all for 99 M6 Fbody
bellhousing to gearbox bolts
bellhousing to block bolts
rear oil pan bolts (ones that go into rear main seal cover)
dipstick and tube (I saw the number for 98 but don't know if its different)
slave cylinder mount bolts
torque arm mount and bracket
fuel tank filler neck and tube assembly
Thanks
Thanks
bellhousing to gearbox bolts: #14050422
bellhousing to block bolts: #22649722
rear oil pan bolts: #12554990.
dipstick and tube: #12551581(indicator) & #12551577(tube).
slave cylinder mount bolts: #11516424.
torque arm mount and bracket: #10252374(inner) & #10252375(outer).
fuel tank filler neck and tube assembly: #10409866(hose) & #10409867(pipe).
fast377
05-01-2006, 11:13 PM
You're the man!! THANK YOU!!
RpSS4844
05-03-2006, 09:04 PM
is Part number 16837696 described as "Camaro front seat back cover....ebony" the covers for the front seats as well as the rears? What I am trying to do is recover some cloth seats from a 97 Z28 to be the original ebony leather that came in my car (2001 CamaroSS). I was a dumbass and sold them and now wish I wouldnt have. What other part numbers would I need to complete this task?
***Also big thanks putting that page together with all the part numbers***
***Also big thanks putting that page together with all the part numbers***Here you go man:
FRT LH & RH ebony seat back cover(leather): #16837696
FRT LH & RH ebony seat cushion cover(leather): #16837698
Rear LH & RH ebony seat cushion cover(leather): #16840531
Rear ebony seat back cover(leather): #16840538
Mike
RpSS4844
05-03-2006, 10:23 PM
Here you go man:
Mike
Thanks for the quick reply!! I looked all these up at GMparts direct, and it is almost $1000 for all the covers :bang: :eyes: :cry: :confused: Does anyone know where to find this stuff more reasonable like $500-$600. That is extremely too much to invest in this project, that doesnt include the stuff i will need to secure them to the seat.
Blue2KTA
05-04-2006, 09:38 PM
2000 Trans Am....Drivers side tail light wire harness part number please.
Thanks
jimmypop13
05-06-2006, 03:17 PM
I need the part number for the exhaust bracket that bolts to the passenger side of the car. It has rubber on the inside of it. The rubber in mine is all worn out so the exhaust rattles on the axle. Every dealership I've gone to doesn't have it in stock but they all quoted me at around $20 so I don't think it's this part number listed earlier:10407350 since list on it is only $13. Thanks!
jimmypop13
05-06-2006, 03:25 PM
I just found it! 10275709
