quick question about reverse
I have a problem with my t56. It very rarely will go into reverse sometimes its like it goes half in and out you can hear the internals in the tranny spinning when it does this but its not in gear. Just wondering if the clutch is the problem maybe it isnt engaging and disengaging all of the way, but if this was the case wouldnt it do this in every gear? thanks
sometimes it will go inot gear fine though.
Its an opereator problem. You are not fully engaging reverse. It could be due to wear/ damage of the clutching teeth on the reverse gear/ synchro that "tricks "you into not throwing it far enough into gear. Use more force.
