Fueling & Injection - Socketless hose?? Good to use or stick with braided?
frcefed98
06-15-2005, 05:21 PM
Well I'm doing a dual intank pump set up, just saw that socketless hose made by russel, aeroquip, and earls...they all have their own brand but looks to be the same stuff. Has anyone used this here on the board. It looks nice and simple to use and easy to install...although doing my braided lines up front wasn't too hard, it was time consuming.
Any NHRA rules about using more than a couple feet of this stuff? I'm thinking doing -8an from the tank to the rail and -6an from the rail to the tank in this stuff.
Thanks all:D
dynedta
06-15-2005, 07:13 PM
I guess its ok to use I asked the same question a week ago clicky!!! (http://www.ls1tech.com/forums/showthread.php?t=336320) I also plan on using it :)
frcefed98
06-15-2005, 07:50 PM
DOH! Thanks Gary, guess I shoulda searched it huh? Got any left for cheap:naughty:
J:D
camrsz
06-15-2005, 10:40 PM
i used this on my car and like it.
stevieturbo
06-18-2005, 05:42 AM
Not sure of the terminology used ??
By socketless, do you mean their push fit hose that doesnt require hose clamps of any sort ? rated at 250psi
If so, Ive used it on most of my fuel system. Its by no means easy to get onto the barbs, but it is pretty neat looking. Defo use oil when pushing the hose on.
-6 hose and fittings from Fuel distribution block, to the rails, then Tee-ing and returning to the regulator.
I used the earls push fit stuff.
You can see it at the front of the rails. It feeds into rails at the rear.
http://images.fotopic.net/?id=14073417
camrsz
06-18-2005, 12:15 PM
I used i heat gun to warm the end of the hose. slides right onto the barb with some lube as well.
stevieturbo
06-18-2005, 12:18 PM
Reminds me...think I did the same.
I locked a male fitting into a vice to hold it, then screwed the barb fitting onto it. Then heated the hose, oiled the barb and hose inside, and pushed it on. Make sure ya get it first go. Once it stops movin, it stops movin, on or off.
V6 Bird
06-23-2005, 01:02 PM
J:DFIND You a local hose supply company...Thats where I gotmine. I paid 50 bucks for the stuff to do my whole car.
That included 10 ft of -10an, 16 ft of -6 and 5 ft of -8.
Mike
frcefed98
06-24-2005, 11:25 PM
haa ha! Just what I did. Action hose here in ALB has the stuff for CHEAP!
But alas my wallet has taken a pounding here lately. So it'll have to wait until it gets up to "mod" capacity again:lol:
Glad I have a V6 firebird to run around in now:burn:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
