Manual Transmission - how to measure clutch disc
2000bean
06-16-2005, 09:37 AM
I just bought a spec stage 3 used. the flywheel and pressure plate have been resurfaced. I was wondering it there were certain specs for the disc that I could measure and see how much life is left on the clutch. any ideas
also the pp on the clutch is painted yellow instead of the usual blue has anyone seen this
2000bean
06-16-2005, 09:41 AM
the guy i bought this from said he just sent it back to spec and had the pp and flywheel resurfaced and balanced together. here is what the invoice from spec said that he emailed me.
customer brought in 2- SC093 & two factory flywheels , upgraded SC093 to SC095, inspected SC093 & factory flywheel, resurfaced both flywheels
SC733--RESET SELF-ADJUSTING MECHANISIM, PRESSURE = 2657psi
LIFT = 1.12; 1.03; 1.08 @ .250 TRAVEL -- DISC .340 THICK
TOTAL WEAR ON UNIT APPROX. .020-.025 -- REBALANCED UNIT
WITH FLYWHEEL
CHARGE SHIPPING ONLY on one unit only - customer picked up one unit already BW
invoice #21030
JRracing
06-16-2005, 10:41 AM
If you don't mind how much did you pay for it, I'm selling my spec 3 with 4K on it , is why I ask. PM me if you don't want to put it up on here. Thanks.
2000bean
06-16-2005, 11:52 AM
i believe this clutch is worn out. I want to make sure before i install it. The throwout bearing he gave me isnt new like it was suppose to be either its used. anyone know how to tell if this clutch is any good
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
