Forced Induction - how to install guages and wiring
StoleIt
06-16-2005, 11:18 AM
did a search and only thread i could find pertaining to this was back in 2002. i've got the dual a pillar guage thingy and boost and fuel pressure. where is a good spot to cut through the firewall to run the lines of these guages. also where would be a good spot to tap the fuel pressure guage (electric, not mechanical) so it can get power?
thanks!
JMBLOWNWS6
06-16-2005, 12:38 PM
When you take the pillar off you can see striaght thru the floor board on the drivers side. I just fished the wires thru there with a hanger. Then just drill a hole thru your pillar. The dimmer light wire is located right by the fog light switch. Its the yellow wire which goes to the white wire + and the black goes to Ground -. The red goes to the key and the black goes to ground. I drilled a hole thru the firewall on the left upper hand side of the brake pedal. The hole will end up right behind the brake booster. I went ahead and cut the wires due to the the fuel sending unit plug hole would have to be huge.
Ferocity02
06-16-2005, 07:44 PM
I drilled a 7/8" hole through the firewall above the brake pedal like him.
Your fuel pressure sending unit will go onto the end of the driver side fuel rail. There is a schrader valve inside the rail that needs to be removed. You will need an adapter to attach the sending unit. Do a search for it in the Fuel section and you will find the part number.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
