what cam for LS1 383?
Old 06-17-2005, 10:21 PM
ta_silver_bullet's Avatar
Question what cam for LS1 383?
i just installed a 383 into my trans am. i have in it right now the small comp xe-r 224/224 .581/.581 lsa114. what would be a good cam to replace it with for N/A performance but when i spray the 150shot it will liek it to just throw up some sugestions yall
Old 06-17-2005, 10:34 PM
Raise's Avatar
how bout the T-rex or the magic stick?? theyre both really aggressive cams with a traditional split for spraying. but....how's your ptv clearance now with the 224 cam??
Old 06-17-2005, 10:39 PM
im not to sure on the ptv clearance the cam was first installed by me into the stock motor then i lost a valve spring and a valve hit the top of #1 piston and well teher was a hole in it. so i had HPE build my 383 and i reused the 224cam. i know we decided to go with 8cc dish and 2cc valve relifs becaus ei was using stock heads i was just seeing if anyone had any good ideas on what i should run and still be very streetable
Old 06-18-2005, 09:07 AM
1BADAIR's Avatar
Mine is a 246 248 .613 .615 114. It idles like my old 346 tr224 112
A few people use 242 250
Old 06-18-2005, 09:57 AM
PREDATOR-Z's Avatar
Do you want max effort or tame?
G5x2/x3 or FM9 are good street/strip sizes with very friendly manners in a 383
Old 06-18-2005, 10:15 AM
lilbuddy1587's Avatar
G5x4 all the way, great manners in a 383. Especially when its time for nitrous
Old 06-18-2005, 02:32 PM
Bo White's Avatar
238/240 XE-R on a 113 LSA is great for a street car with N20.
