larger fuel injectors and fuel pump for procharger
Old 06-18-2005, 04:38 PM
SLP/Drew's Avatar
Exclamation larger fuel injectors and fuel pump for procharger
can someone point me in the right direction so I can upgrade my ls1's fuel injector and fuel pump...Whats a good place that makes aftermarket injectors and pumps that will compliment my procharger setup that I will be getting(9 pds of boost)
Old 06-18-2005, 05:47 PM
Ferocity02's Avatar
http://www.racetronix.com
Old 06-18-2005, 10:32 PM
SLP/Drew's Avatar
what size is our stock fuel injectors?..but more importantly im getting a procharger(9pds of boost); what kind of numbers (lb/hr) should I be looking for when getting an aftermarket fuel injector???
Old 06-18-2005, 11:31 PM
v8juice's Avatar
i have 42lb injectors with the ati,works well
Old 06-19-2005, 02:21 AM
618HAWK's Avatar
SVO 42#s and the
Racetronix intank Plug and play 255. And a fuel pressure gage and you will be set. For 9 psi. Same setup I am runing and working great with no problems.
Old 06-19-2005, 02:54 AM
Ferocity02's Avatar
Anything over 42# injectors is good. I got 60# because I have some big plans for the future, if I can get the kinks worked out.
Old 06-19-2005, 02:57 AM
UnderPSI's Avatar
I have a set of used 42.5 SVO injectors for sale for $175 if you want them. They were in my car with the same setup for less than a year. Got a bigger supercharger now i don't need them anymore. PM or call 262-751-9439 (Sprint Cell)
Old 06-19-2005, 11:21 AM
mdhmi's Avatar
42 # injectors and a Racetronix pump setup worked fine on my ATI D-1SC setup at 10 #'s of boost.
For the TT setup I am switching to 60 # injectors.
Mark
Old 06-19-2005, 03:16 PM
SLP/Drew's Avatar
thx for the input guys...do most of yall use SVO injectors or Racetronix???
Oh yea underpsi I sent you a pm and I was wondering if you had any pics?
Old 06-19-2005, 04:59 PM
Arkangel77's Avatar
I have a set of 50"s for $250 shipped , If you are intrested let me know!
https://ls1tech.com/forums/lsx-parts-sale/338541-f-s-50-fuel-injectors-high-impedance.html
Lata, Ark
Old 06-19-2005, 08:45 PM
SLP/Drew's Avatar
yea im intrested...what will the big difference be between 42#, 50# and 42.5#...their both SVO's and will they fit the same as 42#. I know their is more flow the higher up you go but im wondering on the lines of instillation, tables, and computer programing
thx
Old 06-19-2005, 10:16 PM
Arkangel77's Avatar
Any Time you swap injectors you will need to have the program changed to run them properly. They will fit exactly as your current injectors fit. You just remove the old one and pop in the new ones. They are a direct swap! AS for the diff > Larger injectors will support more power and flow more fuel! Someone correct me if I am wrong. Let me know if you have other questions? Thanks, Ark
Old 06-20-2005, 05:11 PM
LS1TECH Sponsor
Racetronix's Avatar
Not to kill anybody's sale but the Delphi Multec 1 (MSD/Holley) 50's are not a good choice when using the factory LS1 PCM. They do not get along together and for most people are next to impossible to tune. We never recommend the Delphi 50 for LS1 PCM use. The 42's are the largest hi-z injector Delphi makes that is compatible with the LS1 PCM. The next step up from 42's would be Siemens 3172's or L107's.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 06-20-2005, 05:24 PM
red ws6 99's Avatar
The msd 50lb injectors are not that hard, although compared to most injector not that fun. It just takes some tweaks to the injector timing tables since they take twice as long to open as stock injector. Plus the flow rate increase is not linear with pressure increase above 43 psi. It just took me a little digging on the LT1 boards to get the injector timing constants (basically the same as 42 lb lightening injectors). But basically if you have choice go with something else since they are expensive and will take a few a hours to get dialed in (street tuning).
Gary
Old 06-20-2005, 05:29 PM
LS1TECH Sponsor
Racetronix's Avatar
Gary
That is good news as most people are never able to get a reasonable level of drivability with the 50's. Perhaps you would not mind posting your tables on this forum so that other LS1 owners can benefit from your knowledge? This would open the door to other less experienced tuners allowing them to consider the 50's as an intermediate step between the 42's and the 57's/60's.
__________________
>WEB SITE<
Old 06-20-2005, 05:42 PM
Blackbird's Avatar
Motron 60's are working great for me.
Still getting 19/20mph in commute traffic and high 20's on the freeway.
42's should work great for 9psi on a stock motor but if you think you will ever itch for more power your going to be buying twice cause your going to have to step up in size.
Old 02-10-2008, 06:38 PM
12 Second Truck Club
TURBHOE's Avatar
Gary
can you help me with mine? i just bought some as racetronix had them on sell. you would think if they know they are a pain in the *** they would say so on thier web site. my tahoe is running like it has a huge cam without a tune. what do i need to change? please help.
Old 02-10-2008, 08:42 PM
Tirefire's Avatar
Originally Posted by 618HAWK
SVO 42#s and the
Do you have a fuel pressure regulator or are you still using the factory in bucket regulator. Only asking because I'm at 8.5 psi and fuel pressure drops like a rock. I'm also using a MSD boost a pump and a racetronics hot wire kit with no luck to mention..
Old 02-13-2008, 02:27 AM
LS1TECH Sponsor
Racetronix's Avatar
A 2005 thread/post. Wow, time passes quickly!
We now offer 48lb/hr disc injectors which are the same as the popular 42's with increased flow:
http://www.racetronix.com/INJL48.html
__________________
>WEB SITE<
Old 02-15-2008, 02:38 PM
TURBHOE's Avatar
pm sent
Quick Reply: larger fuel injectors and fuel pump for procharger
