What VSS values?
Originally Posted by P Mack
Yeah, I tried putting 2 in the value in hptuners and it accepted it. Your speedometer might act jumpy at low speeds with that low of resolution though.
Is the speedo accurate when cruising along?
Any other symptoms?
My car does have a manual computer so it reads 17 pulses but all I can get in the way of aftermarket inline speed sensors for a TH350 is a 16 pulse.
Will this be accurate enough without changing the values?
If I did my math right it will read 58 when you're going 60 with 3.50's, 16 pulses per rev, 26" tires and a stock m6 pcm. I used:
speedometer reading = actual speed * actual gear ratio/programmed gear ratio * actual pulses per rev/ programmed pulses per rev * programmed tire diameter / actual tire diameter.
GTS346, where did you get the in-line speed sensor from and how exactly does it fit in-line. I`m building an LS1 powered Ford Capri with a TKO 5spd and would much prefer your arrangement rather than a reluctor wheel on the prop-shaft etc.
