Mounting PCM? Does it need grounding?
I have mounted my PCM inside my glovebox, but was going thru a thread and someone mentioned the PCM needs to be grounded? I know there are plenty of ground wires on the harness but does the PCM housing need to be grounded to part of the body?
The factory ones have a plastic insulating case around them but I havent seen 1 up close for ages to remember if its grounded directly or off a wire.
