Dual intank pump pics?
Hope this helps...
http://www.cofba.org/users/smokinhaw...-pics/fuel.htm
btw, I need to get in touch with you some time to see what you guys did for PCV on PUREVL's STS setup. I'm getting ready to start the install, and was wondering how you guys did it.
Heres some of mine. Just make sure the you keep the stock length of fuel line that way your fuel level reading stays the same.
If you going to run a larger fuel line then this little thing will work for you. I got it at Home Depot in the air tool section. I think the 3 bottem fittings are 1/4" and the top one is a 3/8". I had a 1/2 to -8 bulk head so I had to make that work, but I would see if you could get a 3/8 to -8 or -10 to make it fit better.
