Tall curb + My car equals...
what can i do to fix this? can i just bondo it? ive never used bondo either so what do i do and where can i get it? the crack is pretty long. just the fender panel not the door thank god. thanks guys!
*PICS BELOW*
*PICS BELOW*
"The web site you are trying to access has exceeded its allocated data transfer. Visit our help area for more information.
Access to this site will be restored within an hour. Please try again later."
is what your webhost says
I had the same thing happen to me on my camaro but not as bad, I took it to the dealer to try and have them fix it under warranty, which understandably they denied to replace the fender but the did straighten out the bent bracket, so the only way to completely fix it is to find a new fender.
Yeah, you're definately gonna need a new fender for that. I had my car drop off the jack when I was changing a flat and cracked it going up the side right there. It's plastic, so just using bondo won't fix it.
yeah i figured i would just need a whole new fender. is there anything else i could have damaged, or is there just a fender there? i work at a chevy dealership so getting a new one shouldnt be a problem, i hope. thanks for everyones help. and thanks for resizing the pics how hard is it to replace the fender? something i can do at home? any hidden bolts that will probably tick me off? thanks!
There is nothing else under the fender in the area you hit it at. Fender is easy to take off. Remove the bolts holding it inside your engine bay, the two at the bottom of the car and there is one around the mirror area and another bracket at the front of your door.
