Ordering Converter Single or Triple plate?
Old 06-19-2005, 03:51 PM
SCREAMIN's Avatar
Default Ordering Converter Single or Triple plate?
Was going to order my Vigilante 3600 Converter here soon, was wondering if it is worth it paying $165 extra to get the tripple plate converter vs the single plate. I plan on using some form of power adder maybe a year or so down the road but just wanted to hear your opinions. I get free Re-Stalls for 2 years! Thanks
Old 06-19-2005, 05:45 PM
Moderator
jimmyblue's Avatar
If you want to lock it at WOT then get the triple
(or more). If you're going to let it unlock like the
stock tunes do then you aren't going to exercise
the capacity (though towing might). Some folks want
to lock it at the top of 3rd so they can finish in 3rd
at a higher trap, not shift to 4th. With the 3.23 gears
you're not likely to top out 3rd in the quarter mile,
without -mondo- power adder and big base HP as well.
Old 06-19-2005, 06:47 PM
SCREAMIN's Avatar
I might be trapping at 130 + someday, but I was just trying to be ahead of the clock by ordering it ahead of time when I need it
Old 06-19-2005, 11:19 PM
menlatin's Avatar
I'm also debating the clutch. Would the triple plate be able to hold 750-800 lb ft from a turbo'd 355?
Old 06-20-2005, 12:50 AM
cablebandit's Avatar
i know for a fact it will hold 775lb ft
Old 06-20-2005, 01:56 AM
menlatin's Avatar
is that 9.5 or 10.5
Old 06-20-2005, 08:43 AM
CHRISPY's Avatar
get the triple. It is cheap insurance...
Old 06-20-2005, 08:46 AM
PI vig 3800 multidisc...I believe thats 9.5"
Old 06-20-2005, 02:49 PM
LS1TECH Sponsor
1Hawk's Avatar
You can actually get the Vig Multidisc in 9.5 or 10.5........
9.5" lock-up 2004R, 700R4, 4L60E, 4L80E
Multi- Disc 3 plate
2400-6000 RPM's
10.5" lock-up 2004R, 700R4, 4L60E, 4L80E
Multi- Disc 3 plate
2400-6000 RPM's
Multi- Disc 5 plate
2400-6000 RPM's
Vigalante
I would go Multi Disc Right of the bat...Its not that more expensive and it gives you more compatibility
Old 06-20-2005, 04:56 PM
SCREAMIN's Avatar
Ok then multi disc it is!
Old 06-20-2005, 05:14 PM
hotrod04's Avatar
I have the triple disc 10.5 inch 2800 vig in my truck has 200miles on it now and just starting to play with it and wow is all I can say, this thing is the sh_t. really locks tight. Like it.
