1 st gear boggs when you power brake ?
I have a Yank 3200 and my trans was done by atd It works fine except for a couple things.
1. When In 1 st gear manually and you hold the brake and stomp it , It revs just a little and then seams to go into a limp mode . Has any one heard of this happening before ?
2. When I am crusing along and tap the brake the rpms fall way down and then the trans jurks a little then returns to normal.
Any help would be great thanks. Nyle
I just had the car tuned at Livernois , And it still does it. I'm going back in 3 weeks for a turbo install , So maybe they can fix it then. I hope after the turbo install I won't have to power brake it.
Blue vette ! I said I had a converter . It's my sons Z that don't. Hi Jeff.
Thanks.
Thanks.
Bog
Thanks.
Thanks.
Thanks.
Thanks.
