Spark Plug Wires Need Help ASAP
i am changing my spark plugs as we speak....i finished everyhing up to #6 all i have left to do is #8 but i cant get the boot off...this isnt the only problem the main problem is when i pulled off the STOCK plug wires i set them aside in the order i pulled them off so i knew how to put them back on....well i dropped a plug on accident and i jacked up the car and as i was comming out from under the car i accidently nudged the plug wires and im not sure if i have them in the correct order...now if i put them on and they are in the wrong order will the car still crank over? this is what is incsribed on the wires:
PED 32
PED 60
PED 9
is this the correct order?
PED 32
PED 60
PED 9
It doesn't matter in what order the plugs go. To get the cylinder 8 plug wire off, take off the coil pack on that side (all four) and it will give you more room to work with. Also, just letting you know this thread belongs in the external section.
