Nitrous timing retard question
Location: BOSTON IS MY HOME, BUT NOW, IAM A PERMINENT VISITER HERE IN TAMPA.
Im just wondering what is everyone doing these days to retard their timing on their ls1/6's.
Currently on my z06 I had cartek put a timing tricker on my ait sensor, it does the job but im looking into a better way of going about it. It makes the ait jump to 141* thus retards the timing.
I speak to nitro dave on a regular basis and we've decided on the ramchargers timing tuner (and his independent fuel system). It seems like a better way of doing it.
Now I dont have ls edit or hp tuners so I need a SAFE way to retard the timing under nitrous use, I.E. at the track/on the street, 200shot.
Most likely ill go with the ramchargers but lets hear what you guys use....
Thanks
ANDY
Thanks
ANDY
You don't have a lot of options with the LSX platform. They are:
Trick the IAT sensor with a resistor (you already did this)
spray a dry shot
go to a stand alone engine management system, like BS3
get a Ramchargers Timing Tuner
Based on what you said above, your only real option is the Ramchargers Timing Tuner. You could use the Big Stuff 3, but I have a feeling that's overkill. If you have any questions with the BS3 or Ramchargers Timing Tuner let me know!
spray a dry shot
On the IAT, you run it through a relay and toggle switch and arm only for n2o, then no timing pull n/a. You can also replace the set value resistor with a pointotmeter (variable resistance) and dial in what timing pull you want depending on upsizing shot, weather, race fuel. Just another opition for the do it yourselfer.
Sweet idea
This is how I'm setting up mine.
My recommendation is to use a resistor bridge to trick the IAT like you're doing, but to use some tuning software like ls1edit to ensure consistent timing under these conditions.
Consistency is key to keeping things working right.
As far as I know not on the LSX ignition system, well not yet anyways....
Originally Posted by BackinBlack02SS
Can't the new maximizer 2 pull timing as well as all it's other features?
edit: nevermind, it was a stupid question and I didn't read. Conclusion: Pulling timing with Maxmimizer II will be easy. All I need to know is how many ohms equates to 1 degree of timing.
Thanks,
somebody
Thanks,
somebody
I belive MSD is working on an ignition that will compliment thier coils. I would think that it would also have some kind of provision for N2O/FI among other things. Anyone else know anything about this?
Thanks,
somebody
Thanks,
somebody
Robert
