afr 225s and a big cam...flycutting?
I assume you milled the 225's??
If so how much?
Assuming low-mid 60's you WILL be flycutting....
(2.080 valve creates more V to P issues than the 205's with the smaller 2.02 valves).
If so how much?
I do not have either the heads nor the cam. I am looking at going with a 402 sometime next year but I was thinking of going ahead and getting the FAST 90/90 Intake and throttle body along with the 225 Heads to be used on the new motor. I was thinking of using them on my stock cube LS1 for now and switch to a bigger cam. I assume this would be an ok move since I would use that intake and heads on the 402.
Also, what do you do about the difference in the bore size between a stock ls1 and the 4.000 on the 402?
As far as the bore size differences, ANY 225 headed combination must run a 4.125 minimum bore gasket anyway so technically both combinations would take the same head gasket.
Tony M.
